If your worried about accuracy do the math yourself.
It appears fairly accurate though.
Did the math, not sure about port end correction.
subtract 1/2 of port width if your using the walls as part of the port and that would be the right physical length.
You should remember that you design the port based on the woofer, not on the enclosure.
based on enclosure, woofer, and power going to the sub too.
T/S parameters have the largest impact on the design of a port, if you are ever unsure that's the safest thing to design around.
Port velocity changes with box size, tuning, and input power. And port area but that's part of the port design.
Explain what you mean. I assume you're talking about what tuning frequency would sound best with a given driver?
Yes that, Xmax, and Sd.
The sites accurate, it already calculates end correction into it, but it uses the net volume of the enclosure. Meaning it calculates the tuning for the volume you enter which should be after all displacements including port, sub, and any bracing.
