You can learn a lot about uphostery on a fiberglass forum, i'm sure you can get A LOT of tips to help you with the pods there.
I am a member on the fiberglass forum also, There is ALOT of good info and ideas over there.trink40.gif Those guys over there aren't afraid to take a car apart either.peepwall.gif
  • Replies 535
  • Views 57.7k
  • If you want to build things Heavy Duty then fiberglass isn't the solution, but bracing is. Look up the matrix bracing on B&W's speakers and see how it should be done if you are truly into overboa
  • i have read multiple opinions about the glass on the inside of the box, regarding to how it might affect the sound. do you have any words of wisdom on it? in short i see spl guys likeing it more tha
  • Won't be smoother, won't be warmer, just perhaps louder. Either way it won't be an audible difference.
that pod looks amazing on that door. nice wrap job ;) cant wait to see a speaker in there!
i just joined FGF the other day. lots of cool stuff over there.
If anybody needs me I will be outside bolting in my 10" Aura drivers!!!!popcorn.gif
oh, done other than the right signal.lol. I am starting on the high's amp wiring now and then......
I finally concurred the vinyl with the baddass glue and a roller.
I ran 1/4" bolts through the mounting ring in three places, all the way through the door metal and put a washer and metal lock nut on the inside. the bitch is SOLID. no moving way-so-ever.
Its SO SEXY, I couldn't get enough of it!!!!!
That is one SEXY door.....Dude.....I wish I was closer so I could hear that car! Shall I say it? The mid-bass will be EPIC!!!! :drink40:
Fffin' sweet :drink40: , your doors are little sub enclosures. I even like how you wrapped and covered the whole were your tweeters were at. :fing34: :fing34: :fing34: :fing34:
I think we need a video! lol I really like this came out!! Nice man!
$#/+ that is so tight! Are you ever going to get out of that car after the first time you sit in it?
Here's some with the grill installed, I wish I could run them without,BUT....
Here's with the seat all the way forward.
from the drivers seat.
More on the way of the drivers door.
Here's the drivers door with the grill installed.
I pulled the drivers pod in more than the passanger pod with the 1/4" bolts, but right now the window just barely catches the back of the specker SO I will have to adjust one more time.
from the passanger seat.
Damn brother they look f'ing great! So how heavy is the door with the 10" loaded?
The door doesn't feel to bad for all the extra weight. They don't really slam like I was worried about.
I didn't get the chance to put any power to them yet as I just got done mounting them right before I had to come to work.
I will fire them up in the morning, PLUS shouldn't take long to get the dash pods installed.smile.gif
I just got the high's amp wired in. I am using the Rockford fosgate 400.a4 I already had for now.
