Posted January 22, 201015 yr i wanted to know if i could make a ported box with a small trunk. the dimenions are 11 1/2 height, 15 depth, 46 length. thanks
January 22, 201015 yr i wanted to know if i could make a ported box with a small trunk. the dimenions are 11 1/2 height, 15 depth, 46 length. thanksThats not a trunk. Sounds like a couple shoeboxes. If thats all the room you have, it will be tough.
January 22, 201015 yr x2, I would personally shoot for a 12" with that size trunk, plus it will leave you with some more room for other things
January 22, 201015 yr Author x2, I would personally shoot for a 12" with that size trunk, plus it will leave you with some more room for other thingscould i port the 12?
January 22, 201015 yr Author i wanted to know if i could make a ported box with a small trunk. the dimenions are 11 1/2 height, 15 depth, 46 length. thanksThats not a trunk. Sounds like a couple shoeboxes. If thats all the room you have, it will be tough.haha i know i hate it. and its a convertible so i cant put it in the back of the car
January 22, 201015 yr Why not?i really dont know this is my first buildYou are going to want to port that if you want to be able to hear it in your convertible.
January 22, 201015 yr Author Why not?You can port any size driver, I have seen a 6.5" driver ported before.sweet im prob gonna get a 12" earthquake subzero it has a mouting depth of about 7 1/2
January 22, 201015 yr Author Why not?i really dont know this is my first buildYou are going to want to port that if you want to be able to hear it in your convertible.yea thats what ive heard
January 22, 201015 yr Author Why not?i really dont know this is my first builddo u have any guess on how big the box should be or rough dimensions
January 22, 201015 yr Why not?i really dont know this is my first builddo u have any guess on how big the box should be or rough dimensionsIt depends on big of a driver you will use, 12" or 15"? The same Choas series?
January 22, 201015 yr Author Why not?i really dont know this is my first builddo u have any guess on how big the box should be or rough dimensionsIt depends on big of a driver you will use, 12" or 15"? The same Choas series?12" and no i actually found a earthquake subzero sbwoofer for 200Subzero Subwoofers this is a link of it. it has a mounting depth of 7 1/2
January 23, 201015 yr Why not?i really dont know this is my first builddo u have any guess on how big the box should be or rough dimensionsIt depends on big of a driver you will use, 12" or 15"? The same Choas series?12" and no i actually found a earthquake subzero sbwoofer for 200Subzero Subwoofers this is a link of it. it has a mounting depth of 7 1/2Im not able to enter the subzero catagory. I cant see the specs.
January 23, 201015 yr Author Why not?i really dont know this is my first builddo u have any guess on how big the box should be or rough dimensionsIt depends on big of a driver you will use, 12" or 15"? The same Choas series?12" and no i actually found a earthquake subzero sbwoofer for 200Subzero Subwoofers this is a link of it. it has a mounting depth of 7 1/2Im not able to enter the subzero catagory. I cant see the specs.This is all i can find http://www.earthquakesound.com/IMAGEJP/CAR/pdf/subzero12manual.pdfwell lets say the chaos 12" for now Edited January 23, 201015 yr by mustangsub
January 23, 201015 yr You can make it work but the enclosure will be very long to get the volume you need with the chaos.
January 23, 201015 yr Author You can make it work but the enclosure will be very long to get the volume you need with the chaos.any idea how long were talkin? cuz i got bout 47inches to work with
January 23, 201015 yr You can make it work but the enclosure will be very long to get the volume you need with the chaos.any idea how long were talkin? cuz i got bout 47inches to work withTry plugging in some numbers with this. RE calc. Its not going to be exact and it leaves out the driver displacement but it will give you a good idea of how large it needs to be. Its probably going to be over three feet long.
January 23, 201015 yr Author You can make it work but the enclosure will be very long to get the volume you need with the chaos.any idea how long were talkin? cuz i got bout 47inches to work withTry plugging in some numbers with this. RE calc. Its not going to be exact and it leaves out the driver displacement but it will give you a good idea of how large it needs to be. Its probably going to be over three feet long.this is what i got. 35 width, 10 height, box top and bottom depth 14.5, .75 thickness, port height 8.5, port width 1.5, port lenght 12.25, port length 2: 10. the box volume was 1.94 and the frencecy was 25 Edited January 23, 201015 yr by mustangsub
January 23, 201015 yr You will have to flip flop some numbers to get them exactly right. 25hz sounds pretty low to me. A wider port is a good idea as well because 1.5" is a little slim also. I would go about 2-3" on the port width. The enclosure will look really funny and Im not even sure the shape is very optimal. Its possible but...Have you ever thought about glassing to get maximum volume from your trunk?
January 23, 201015 yr Author You will have to flip flop some numbers to get them exactly right. 25hz sounds pretty low to me. A wider port is a good idea as well because 1.5" is a little slim also. I would go about 2-3" on the port width. The enclosure will look really funny and Im not even sure the shape is very optimal. Its possible but...Have you ever thought about glassing to get maximum volume from your trunk?what is glassing?
