February 13, 201016 yr yea i would think u should b fine...i have the 1610 on stock alt and battery, and i have it turned about 3/4 up and my voltage only drops to about 13 volts.
February 13, 201016 yr Author That's what's up man. I guess I'll have to do that part after everything else is installed. I guess I should do big 3, then alternator, and then the 2nd battery. Well an update on where the BTL is at: It arrived in Memphis, TN today and shipped to Nashville, TN (30 minutes drive from me) and the lastupdate is departure from Nashville,TN to Murfreesboro,TN (My town). I wish there was a way to pick it up tomorrow =(. Its like torture having to wait 2 extra days when its 5 minutes away from you. lol
February 13, 201016 yr I have a powermaster 200amp in my chevy. I have had this alt for 7-8 years now, Definetly a name you can trust. My is part number 48202. Don't buy cheap you will regret it.
February 13, 201016 yr I have a powermaster 200amp in my chevy. I have had this alt for 7-8 years now, Definetly a name you can trust. My is part number 48202. Don't buy cheap you will regret it.x2
February 14, 201016 yr Author I have a powermaster 200amp in my chevy. I have had this alt for 7-8 years now, Definetly a name you can trust. My is part number 48202. Don't buy cheap you will regret it.x2I will look into them, thanks for all the advice guys.Well today I was a little bored and I ran my power wire a little bit better, and think I'm moving my ground. I'll show where my ground was, and I guess I should do it to the frame, but I dont have enough ground wire for that. Will the ground I have now be good? Also mounted the amp on the box, and ran the speaker wire from amp to inside the box. Just some boring stuff... Heres some picsAmp mountedWhat the wires look like on the insideHeres where the power wire is ranWhere is comes out and here is where my ground question is
February 14, 201016 yr Good job on the wire, I hate tearing apart the interior to run wires. It's such a bitch.Also, on the alternator, call around to some auto electric shops and see what it costs to rewind your alternator.
February 15, 201016 yr Author Tomorrow is when the BTL will arrive! I will be cutting the hole in the box, painting/gluing the top on, siliconing the top, then it must dry overnight and maybe a little longer. So I'd say Tuesday/Wednsday I will be hounding hopefully, if I dont run into too many problems. I will have pics of the unboxing and everything else. It should arrive by at least 2:00PM Central time, so check back about 3 or 4 for some pics of the unboxing. =) Thanks everyone for your comments/opinions/advice, I really appreciate all the feedback from you guys. Check back tomorrow for updates!
February 15, 201016 yr Tomorrow is when the BTL will arrive! I will be cutting the hole in the box, painting/gluing the top on, siliconing the top, then it must dry overnight and maybe a little longer. So I'd say Tuesday/Wednsday I will be hounding hopefully, if I dont run into too many problems. I will have pics of the unboxing and everything else. It should arrive by at least 2:00PM Central time, so check back about 3 or 4 for some pics of the unboxing. =) Thanks everyone for your comments/opinions/advice, I really appreciate all the feedback from you guys. Check back tomorrow for updates!
February 15, 201016 yr Your lucky you have room for the 18"BTL. I would too but the Honda wasn't having it. I started out only going to get the 12" but am making the 15" fit! I can't wait to see the pictures, It just never gets old seeing a fresh BTL in the box!!!If I where you, I would drill a hole, bolt the ground to the floor with a nut on the under side and run another ground under the body to the frame from the same bolt. Don't forget to clean to BARE METAL. A vehicle with a frame can NEVER have enough grounds between body and frame, Body and engine, Engine and frame. On my Chevy a couple extra ground straps between even made all the body lights brighter as they are only grounded to the body.
February 15, 201016 yr Author Your lucky you have room for the 18"BTL. I would too but the Honda wasn't having it. I started out only going to get the 12" but am making the 15" fit!I can't wait to see the pictures, It just never gets old seeing a fresh BTL in the box!!!If I where you, I would drill a hole, bolt the ground to the floor with a nut on the under side and run another ground under the body to the frame from the same bolt. Don't forget to clean to BARE METAL. A vehicle with a frame can NEVER have enough grounds between body and frame, Body and engine, Engine and frame. On my Chevy a couple extra ground straps between even made all the body lights brighter as they are only grounded to the body.Thats a good idea, I never thought of doing that. I dont think I have enough ground wire though. Guess I'll have to look in to buying a couple extra feet, or I could cut off some of my extra power wire and use that right?I
February 15, 201016 yr Yeah ground wire and power wire are the same thing, just usually a different jacket on them to help tell the difference when installing.
February 15, 201016 yr If i ever have to use the same color wire for something I put rings of black electric tape on each end of the ground so I know which is which. If it's just for a ground strap under the body you can't really get confused though. Don't forget to clean both sides of the body where you sandwich it.
February 15, 201016 yr Author OMG Its finally here!!!!!!!!!!!Just cut the hole, now I gotta go to work =(. I'll paint the top tonight, and let it dry overnight and in to the day. Here's pics!I'll have more pics later! Gotta go!
February 15, 201016 yr please keep packaging, must of started putting those on after what happened to the 12 BTL
February 16, 201016 yr Your 18" is beautiful, a picture just doesn't begin to show how big it is.Did you make the UPS guy carry it all the way to the door? That would of been fun to watch.My UPS guy was like a Ninja, I went outside and the box was already sitting there. He was probly like "wtf".
February 19, 201016 yr Author Here it is The video shows up in the editor, but disappears when I publish it. theres the link tho, sorry! Edited February 19, 201016 yr by xX Mavr1ck Xx
February 19, 201016 yr arn't you glad our rear view mirrors are connected to the top and not the windshield
February 19, 201016 yr Author arn't you glad our rear view mirrors are connected to the top and not the windshield Very glad lol. I'm very very very very happy with this purchase, and it was worth every dollar. The next major move, is new mids and highs. I was thinking 4 tweeters up front, 2 mids up front and 2 in the rear. When I went to get my system checked out at a local audio shop, he said they could what I wanted with a 4 channel amp for $600 installed Is that a good deal? I don't really know how much mids and highs. The brand he had me looking at was Ample for the speakers and I forgot what amp? Anyone have experience or opinion on that brand?
February 19, 201016 yr I wouldnt do 4 tweeters up front, just stick with a nice set of components unless you want to go active and then that is a different story. You will need a 2 channel amp for a passive (component setup) and a 4 channel amp for an active (2 way setup).
