I have a beautiful box that was built specifically for my vehicle. Now im going a different direction with my setup and I want to lower the tune on the enclosure. I have done a little research and I know that decreasing the port width will lower the tune of my enclosure but i will have to sacrifice a little port area to do so. What are the pros and cons of doing this?
By the way the enclosure is tuned to 35 hz and i would like to change it to about 30 or 31. I currently have 100 in squared port area.
Decreasing port length will raise tuning.
I would just shrink the width of the port..you may increase port noise slightly but it will be cheeper than building
a new enclosure
you could add more port length but it will mess with the interior volume
Not port length. Port width. The width of the opening of the slot port
Its a kerfed port so hopefully the extra port noise will be minimal
Very nice looking box! As Thumpper said shrinking the width looks to be the easiest option.
Thanks. Yea thats gonna be the easiest option. I would just build another box but it wouldnt be near the build quality of the one i already have
With that kerfed edge I'd just glue a 1/2" piece of wood onto the bottom edge of the inside of the port. Or whatever size wood would suffice to get the port area you want. What is the box volume and length of the port now? It might be worth looking into if lengthening the port would still get you desired tuning without lowering box volume below an acceptable threshold.
At what point does the human ear start to notice a differance in tuning freq. change? How close to desired freq. is good enough?
As soon as you have a 3dB shift in the signal it will be audible and perhaps memorable.
Im switching over to a to a Xcon and im trying to make this enclosure as optimal as possible. Im really going for a setup that sounds great and can play loud. I know that you have to sacrifice one for the other so I'm leaning more toward great sound. I'm also going to run a active front stage with Mach 5 6.5's and seas tweeters. Probably a sundown 50.4. I learned alot about active set-ups from you M5 and other members on here that know alot about sq setups. I appreciate any feedback on what I'm trying to do
Im definately going to try a sealed enclosure eventually and see which one i like best. Right now I'm focusing on sound deadening the snot out of my truck. I cant stand any rattle. Next Im going to work on placement of my front speakers
