Posted July 4, 200520 yr Hey guys, newbee here, Ill be receiving my Rl-p in a day or two(I hope), I hear and read alot of mixed opinions on breaking in your subs. Is this necessary? If so what does anyone recommend?
July 4, 200520 yr Not necessary, set the gains correctly, turn on the stereo, run it at low levels and listen to the sub to make sure there is nothing mechanically wrong. If all is good, crank it up.
July 4, 200520 yr Author Not necessary, set the gains correctly, turn on the stereo, run it at low levels and listen to the sub to make sure there is nothing mechanically wrong. If all is good, crank it up.<{POST_SNAPBACK}> Thx Neon, U can be assured cranking will be done. Happy 4th everyone!!!!
