Posted February 5, 201016 yr Ok.. ive seen this in these forums before.. just never fully understood. can one of you pro's explain to me the method used to securely and safely mount these beast's into their box? Maybe even a direct link to a picture of what i need. I also want something that will take a thief along time to unscrew if the little bastards go for my system. Just go ahead and ignore this thread once we get a good answer posted, let it fall to the bottom,. Appreciate your help.
February 5, 201016 yr I wouldn't use anything other than T-Nuts and bolts to mount larger drivers like the BTL. Screws destroy the wood and make it almost impossible to re-use the enclosure.
February 5, 201016 yr I wouldn't use anything other than T-Nuts and bolts to mount larger drivers like the BTL. Screws destroy the wood and make it almost impossible to re-use the enclosure.x2, another plus for the enclosure i am using is that you can't take the sub out without sliding the box out....and it's bolted down solid
February 5, 201016 yr I wouldn't use anything other than T-Nuts and bolts to mount larger drivers like the BTL. Screws destroy the wood and make it almost impossible to re-use the enclosure.ughh, ive used screws already, can i re do it with tnuts and bolts?
February 5, 201016 yr I wouldn't use anything other than T-Nuts and bolts to mount larger drivers like the BTL. Screws destroy the wood and make it almost impossible to re-use the enclosure.ughh, ive used screws already, can i re do it with tnuts and bolts?Yes, you sure can. Just drill a hole the sice of the bolts your using where your screw holes are.
February 5, 201016 yr As long as you don't plan on taking out the sub very often (or, like me, never), screws are ok. Different heads on the screws helps with theft prevention. But ideally, yes t-nuts or bolts are better.
February 6, 201016 yr Author ok, t nuts and bolts.. now what in the hell are those? lol.. im gonna do some googling.. anyone got a link go ahead and throw it up for me, appreciate it.
February 6, 201016 yr ok, t nuts and bolts.. now what in the hell are those? lol.. im gonna do some googling.. anyone got a link go ahead and throw it up for me, appreciate it.Woodworking Assembly Hardware - T-NutThere you are, sir.
February 6, 201016 yr Author crap... one more question LOL.. since i dont have the speaker in front of me, what aprox. size do i want to order these in?
