Posted February 16, 201015 yr I was just wondering, if when adding a port to your box do I minus the width of port and then I'll have my true area of space the actual woofers will be in?
February 16, 201015 yr Doh... I re-read the question! Yes it will give you the true area the speaker will be in.Too damn early in the morning!
February 16, 201015 yr I was just wondering, if when adding a port to your box do I minus the width of port and then I'll have my true area of space the actual woofers will be in?If you mean subtract the volume of the port and then you'll have the true volume the woofers will be in, then yes. If it is an internal port, obviously.
February 16, 201015 yr Author I look at the thread I couldn't find that throughout all out the other forums thanks. This will be the first box I'm ever going to build if you haven't notice. So fellas wish me luck.
February 16, 201015 yr good luck man , dont be scared to ask questions we will help you and guide you along with making a good enclosure. I went around looking at different build logs to just get a feel for what I will be dealing with or how to set things up and so forth.
