February 17, 201016 yr 1) Attach power wire to each side of the fuse holder with fuse in it.2) Behold your mastery of fuses.Just be sure to unhook the negative terminal from the battery first.
February 17, 201016 yr What is the proper wiring process for putting in a fusePlease read new topic guidelines before posting again. Make sure car is off and battery is unhooked, but where and what are you putting a fuse?
