so what is better between a stock Q and a loaded SSD? SPL and SQ wise?
More SQ with the Q that I know of, if your worried about output then Q is not for you. If SQ is your goal then the subwoofer should be the last thing your worried about. I cant really comment on which would have better output, but you should be comparing the SSD's and BL's in your case. Know if you want a good sounding woofer than anyone that FI makes will fit the bill, hope that helps.
ok thanks. i'll probably go with the SSD with bp power option and flatwind coil. i just want a good daily subwoofer with good sq, but will still bump really good. thanks for all the help
so the BTL would be better than the Q or the BL? even though the power i am running would be more geared towards a Q or a BL? i was originally planning on getting a Q or a BL, but i want "the best" haha. but i dont want to have to upgrade my amp quite yet, so i was just wondering if this would be better than going with a Q or BL... thanks guys
Better is subjective, louder is not. Even on 1watt the BTL will be the loudest sub that Fi makes. By a bunch. If that is what is better to you, by all means get it. On the same note if that is your goal, definitely not the Q.
i think i'm gonna try'n save some money and go with a loaded SSD...... cuz i want to get some good component speakers too. thanks for all the help guys
