Posted March 11, 201016 yr Just wondering, when connecting from engine block to chassis ground, can I mount from the air compressor bolt to chassis ground? the air compressor is all metal, so i assume its grounded, since it lays on top of the engine.thanks in advance
March 11, 201016 yr Author so will using the air compressor be as effective as the alternator, or even a effective at all?
March 11, 201016 yr so will using the air compressor be as effective as the alternator, or even a effective at all?Could you post a pic of said compressor?
March 11, 201016 yr Pretty much almost any bolt that is somehow attached to your engine will do as long as if you remove it nothing ill will come of it.
March 11, 201016 yr Pretty much almost any bolt that is somehow attached to your engine will do as long as if you remove it nothing ill will come of it.correct. also make sure it's sanded down bare
March 11, 201016 yr Author great, my chassis ground is all metal no paint on it, my car is a 95' ford explorer btw.thanks guys for the feed back
March 12, 201016 yr Author and in case your wondering, this is my air compressor, you cant see my alternator, since its on the other side of the engine block. You cant see the bolt on the pic, but its a little below the pic Edited March 12, 201016 yr by thizzkid
