March 15, 201015 yr Author so your what your really saying is the best option for me would be to just do a bigger batt under the hood and a 200 amp alt.... this isnt for competition its a daily driver
March 15, 201015 yr Depends on listening habits and what not. I would get a good battery under the hood and install a voltmeter, after installing your equipment watch your voltage. If your voltage falls then you need more electrical upgrades and if not then you will be fine.Start with a battery, volt meter and make sure you complete the Big 3 then go from there (more than likely you will need a secondary battery or ho alternator or both).
March 15, 201015 yr Thats where I personally would start. This will yeild you the best results. Just don't forget to do the big 3.
March 15, 201015 yr Author Depends on listening habits and what not. I would get a good battery under the hood and install a voltmeter, after installing your equipment watch your voltage. If your voltage falls then you need more electrical upgrades and if not then you will be fine.Start with a battery, volt meter and make sure you complete the Big 3 then go from there (more than likely you will need a secondary battery or ho alternator or both).i think ill go that route i was already planning on getting a h/o alt anyway
