I have a Fi Bl 12" which is fully loaded and i need to build another box for it.
I think my first one is not the correct dimensions for this speaker.
Are there any good tutorials or even someone with a box design. I want to make one with 33Hz
Thanks a lot
Patrick
There's an absolute TON of information on enclosure design and building practices on the interwebz, search is your friend on that one. Problem is no one can help you design a box without first knowing some very important information. We need the maximum dimensions you have available for the enclosure, an idea as to how you'd like to have the sub and port located on the enclosure (i.e. sub up/port back, sub up/port up, sub forwad/port up, etc.). A little bit of info like that will go a long way in helping you to design and get the PROPER enclosure for that sub built.
sorry about that, forgot to include that stuff
i just have trouble with ported boxes.
I want an up facing sub with a front port
max height is 14" and max depth is 18"
what about width?
man im really interested in making this sub my next purchase. After you get the box and stuff together if you can post some vids or updates
what about width?
width doesnt matter as much, but it is a tight space and height and depth matter
  • 2 weeks later...
what about width?
I like how he just stopped replying. He asked you how wide you're trunk is mang come on now.. My max space was 33.25w, 17.5h, 24d at least for the sub to work properly. In order to build a box you need to know how its gonna fit in you're trunk.
Edited by Danknugz18
