Posted March 15, 201016 yr Just wondering if anybody knows anything about the Rockford Fosgate RF-BLD. it says install it as close to the source unit as possible, why is that? Why can't it go in the trunk by the amp?
March 15, 201016 yr Just wondering if anybody knows anything about the Rockford Fosgate RF-BLD. it says install it as close to the source unit as possible, why is that? Why can't it go in the trunk by the amp?They probably mean between the source unit and whatever is next such as crossovers or amps, that is how most line drivers are. Why do you think you need it?
March 16, 201016 yr hey i had a buddy with one, past tense, and he regrets ever spending th 50-60$ on it.!. but if you really need one they go inbetween the inputs of the amp and the h/u you hook them up to a +12 sources you set the gain on them for say 5volts and then set the gain on your amp accordinglythey only say to keep it as close as posible so you keep the integrity of the signal strengh, as the run gets longer there is more of a changes of interferance and noise and blah blah so to get the best quality signal keep it close... does it matter if you put it 10ft or 10inch from the h/u for my buddy's setup NO, he also DID NOT need it!
March 16, 201016 yr Are you sure you need it? 99% of people don't need them.so what you trying to tell him is if there are 6billion ppl on the Earth only about 60,000 people actualy need one of these inventions? lol! i like Less ppl then that need them lol!
March 16, 201016 yr Just wondering if anybody knows anything about the Rockford Fosgate RF-BLD. it says install it as close to the source unit as possible, why is that? Why can't it go in the trunk by the amp?Installing it near the amp partially defeats the purpose.Ideally the higher signal voltage increases the signal to noise ratio of the signal transfer. The noise being induced into your system is independent of the voltage of the signal. It will stay the same regardless. So as you increase the voltage of the signal the level of the noise will be smaller in proportion to the signal, which increases the signal to noise ratio. If you place it near the amp, then the signal traveling the farthest (and typically noisiest) distance is the "original" voltage level from your headunit, and you aren't increasing the signal voltage until after the noise has already entered the signal (which means the voltage level of the noise will also be increased since it's now part of the signal at this point). The RF-BLD also features balanced differential outputs which aids in noise reduction. Again, if you are using this feature then having the unit placed near the amp would defeat the purpose. You would want this placed on the source side of the signal transfer so that any noise induced during the signal transfer is able to be handled by the balanced system. If you put the system in the trunk, then the signal entering the unit already has the noise included with the signal.Putting the unit in the trunk would be a little like putting a condom on after you've had sex.That said.....why do you think you need one?
March 16, 201016 yr Just wondering if anybody knows anything about the Rockford Fosgate RF-BLD. it says install it as close to the source unit as possible, why is that? Why can't it go in the trunk by the amp?Installing it near the amp partially defeats the purpose.Ideally the higher signal voltage increases the signal to noise ratio of the signal transfer. The noise being induced into your system is independent of the voltage of the signal. It will stay the same regardless. So as you increase the voltage of the signal the level of the noise will be smaller in proportion to the signal, which increases the signal to noise ratio. If you place it near the amp, then the signal traveling the farthest (and typically noisiest) distance is the "original" voltage level from your headunit, and you aren't increasing the signal voltage until after the noise has already entered the signal (which means the voltage level of the noise will also be increased since it's now part of the signal at this point). The RF-BLD also features balanced differential outputs which aids in noise reduction. Again, if you are using this feature then having the unit placed near the amp would defeat the purpose. You would want this placed on the source side of the signal transfer so that any noise induced during the signal transfer is able to be handled by the balanced system. If you put the system in the trunk, then the signal entering the unit already has the noise included with the signal.Putting the unit in the trunk would be a little like putting a condom on after you've had sex.That said.....why do you think you need one? greatest analogy ever
March 16, 201016 yr Are you sure you need it? 99% of people don't need them.so what you trying to tell him is if there are 6billion ppl on the Earth only about 60,000 people actualy need one of these inventions? lol! i like Less ppl then that need them lol!6 billion people aren't into car audio though.
March 16, 201016 yr good point! my o my you are a quick one!! but this also doesn't look very good for a line driver lol!Are you sure you need it? 99% of people don't need them.so what you trying to tell him is if there are 6billion ppl on the Earth only about 60,000 people actualy need one of these inventions? lol! i like Less ppl then that need them lol!6 billion people aren't into car audio though.
