Posted March 18, 201015 yr i have some questions about the fi q and thought you guys might have some answers. first i was wondering when the new ones are going to come out? it says they were coming out march 1st but its the 17th and it still says that....... second i was wondering if you guys thought the sundown audio saz-1000d would be a good amp to power it with? thanks for the help guys i really appreciate any info you can give me.
March 18, 201015 yr first things firstwelcome to SSAthe Fi Q will be out when they have tinkered with it and are ready to go.the Sundown SAZ 1000D would be a very solid choice to go with. I dont know what your electrical upgrades are but i would suggest the big 3 and a volt meter
March 18, 201015 yr i have some questions about the fi q and thought you guys might have some answers. first i was wondering when the new ones are going to come out? it says they were coming out march 1st but its the 17th and it still says that....... second i was wondering if you guys thought the sundown audio saz-1000d would be a good amp to power it with? thanks for the help guys i really appreciate any info you can give me.They will come out when they are ready, so just be patient (just keep checking the site daily). That amp would work fine with that subwoofer, sets your gains right and bump away.
March 18, 201015 yr Author well thanks for the welcome. and yeah im also probly gonna be running a second sundown amp to power my mids and highs so i was thinking of doing the big three and also upgrading my battery. any suggestions for a good battery? and how hard is it to do the big three?
March 18, 201015 yr well thanks for the welcome. and yeah im also probly gonna be running a second sundown amp to power my mids and highs so i was thinking of doing the big three and also upgrading my battery. any suggestions for a good battery? and how hard is it to do the big three?depends on where your alternator is placed. That can either make it difficult or very easy
March 18, 201015 yr Author im going for a sound quality system not all spl. im planning on running focals in the front and putting the q in a fiberglass box in the trunk. i drive a 98 honda prelude and making this a very clean looking install that sounds good is definately my goal.
March 18, 201015 yr im going for a sound quality system not all spl. im planning on running focals in the front and putting the q in a fiberglass box in the trunk. i drive a 98 honda prelude and making this a very clean looking install that sounds good is definately my goal.sealed enclosure guessing? after just looking at a pic of your engine the alternator looks pretty easy to get to. So it should be relatively easy. just these three stepsalternator to positive side on batteryengine block to negand neg to chassis
March 18, 201015 yr Author ok. ill plan on doing that. but for now its one thing at a time. im buying products as i can afford them and then once i have everything i need ill put it all in. but does anyone have any suggestions for a good strong battery to recommend. preferably not mainstream. i like supporting the smaller american companies rather than larger.
March 18, 201015 yr Author and yes a sealed enclosure. a ported would make it way to complicated for my backyard mechanics......lol
March 18, 201015 yr Does anyone know the specs for the 2010 Qs? I am interested in getting one when they debut. And also, how much power can u place on stock electrical systems. Currently I am running an 03 pathfinder with a pioneer FH-P800BT and stock Bose speakers. I wanted to add a single 12" Q and amp to power it. Would this be to much power for the stock electrical system?
March 18, 201015 yr Does anyone know the specs for the 2010 Qs? I am interested in getting one when they debut. And also, how much power can u place on stock electrical systems. Currently I am running an 03 pathfinder with a pioneer FH-P800BT and stock Bose speakers. I wanted to add a single 12" Q and amp to power it. Would this be to much power for the stock electrical system?Nobody knows the specs of the 2010 Q's, will be posted when they are ready for purchase. It is hard to tell how much a stock electrical can handle depends on alternator, battery and other things. That may work fine with your electrical, buy a volt meter and do the Big 3 then go from there.
March 19, 201015 yr i have some questions about the fi q and thought you guys might have some answers. first i was wondering when the new ones are going to come out? it says they were coming out march 1st but its the 17th and it still says that....... second i was wondering if you guys thought the sundown audio saz-1000d would be a good amp to power it with? thanks for the help guys i really appreciate any info you can give me.New specs are up on the Q and it says they will be ready for sale on the 31st of March
March 20, 201015 yr So im obviously new to FI and SSA. And im pretty much new to car audio as well. On the Q specs, what do all the specs do? Cooling is obviously cooling but why is it add on option? What is P Chamfer? High QTS? Spider? I Heat Ring? im a newbie. lol
March 20, 201015 yr Options are explained in the technical section.Cooling includes a pole chamfer, a pole chamfer plugs the pole vent (on the bottom of the woofer) forcing more air to go around the coils increasing thermal power handling.Select High QTS if you will run the woofer in a sealed enclosure.Spider is adding an extra surround to increase mechanical power handling.I'm not sure why they added an induction ring, to increase thermal power handling possibly?
March 20, 201015 yr ok thanks. So optimal settings would be to add it all on? If i just want to run the sub at its standard 1000rms in a ported box do I need to add any of these? what do yall recommend?
March 20, 201015 yr im going for a sound quality system not all spl. im planning on running focals in the front and putting the q in a fiberglass box in the trunk. i drive a 98 honda prelude and making this a very clean looking install that sounds good is definately my goal.If that is truly the case, buy something other than the focals, worry less about the sub and start asking installation questions as that will have a much, much, much greater effect on the SQ in your system.
March 20, 201015 yr ok thanks. So optimal settings would be to add it all on? If i just want to run the sub at its standard 1000rms in a ported box do I need to add any of these? what do yall recommend?Read the technical site and see which ones will apply to your application:SSA Car Audio Forum -> Fi Technical
March 21, 201015 yr jay-cee i dont see where you are pointing me to lol. Under FI Technical I saw the Q Enclosure feed but that just mentioned Bp power which was for the older models i believe. Is this where u intended me to look or is there something else there?
