Posted March 22, 201015 yr Hello today is my first day on here and I hoping that maybe some of you guys on here could tell me of a better sub on the market that would be louder than my hifonics goliath 12" sub. here are the specs for you:quad coil 2 0hm2400rms and 4800 peak wattsfoam surroundaluminum cone3"voice coil160 oz mag. it weighs 38 lbsit is n a ported box think it is n like 2.5 cubesand I have a hifonics bxi 2608 ampI am wanting a single sub. I have an eclipse so i dont have much space to work withplease help! thanks
March 22, 201015 yr Welcome to the site. And before you get to beat up i would suggest you mention what kind of goals you are looking for? Not just a better sub. What are you looking for it to do? What kind of budget? What size's can you work with? Well GL with it all anyways!!
March 22, 201015 yr Welcome to SSA! Before you look at buying a new driver, look at building an enclosure to optimize your current subwoofer.
March 22, 201015 yr Author Hello today is my first day on here and I hoping that maybe some of you guys on here could tell me of a better sub on the market that would be louder than my hifonics goliath 12" sub. here are the specs for you:quad coil 2 0hm2400rms and 4800 peak wattsfoam surroundaluminum cone3"voice coil160 oz mag. it weighs 38 lbsit is n a ported box think it is n like 2.5 cubesand I have a hifonics bxi 2608 ampI am wanting a single sub. I have an eclipse so i dont have much space to work withplease help! thanksI want it for compatition and I only want one 12" or one 15" sub. I think I have plenty of power for ne sub of that size
March 22, 201015 yr If you already have a decent sub, why are you wanting to change? Can you explain the reason for needing to change? What is your budget? Have you thought about redoing your current enclosure? Is it gonna be a one note wonder, or a daily also? There is alot of questions that you should help answer first. This site is great for helping, but we need to know what we are trying to help first.
March 22, 201015 yr Welcome to SSA! Before you look at buying a new driver, look at building an enclosure to optimize your current subwoofer.x2
March 22, 201015 yr Straight SPL competition ??? Street beat ??? Power Class ??? These things Will make a VERY big difference in determining tuning frequency.
March 22, 201015 yr Welcome .... Try building a new enclosure to maximize the woofer you already have. If you still don't like it then change it out!
March 22, 201015 yr Welcome to SSA! Before you look at buying a new driver, look at building an enclosure to optimize your current subwoofer.x2x3
March 23, 201015 yr Author If you already have a decent sub, why are you wanting to change? Can you explain the reason for needing to change? What is your budget? Have you thought about redoing your current enclosure? Is it gonna be a one note wonder, or a daily also? There is alot of questions that you should help answer first. This site is great for helping, but we need to know what we are trying to help first.I want to change because when I really turn up my music and straight blast it my sub starts to give off a funny smell. Is it about to blow? all of my hifonics speakers make that smell. I thought that it was bad and that i am about to fry them. I run them for about 2 mins after I first smell the coils then I turn it down for a minute or two then go at it again. and what kind of box, how big and is the goliath quad coil sub sub ne good that i have? is a L7 better? or solo x better? what is a louder sub. or am I about maxxed out in the 12" range. I want to be able to listen to my music and turn it up ass loud as my lil ears can handle it.... maybe I just need one bad a** box
March 23, 201015 yr Author Welcome .... Try building a new enclosure to maximize the woofer you already have. If you still don't like it then change it out!what kind of enclosure? how big and what kind of port?
March 23, 201015 yr Hello, Let's start this way by asking you what kind of box are you running now sealed or ported??? For you to be gtell us about your box now and we can go from there....getting a smell from your coil most likely the box is not the right size and your amp may be clipping ... Hawk Edited March 23, 201015 yr by thehawk93
March 23, 201015 yr That's not how it works hawk.If you are smelling burning coils your pushing the thermal power handling of the woofer, your enclosure is pushing larger than recommended airspace, that can cause some problems.
April 3, 201015 yr may i ask how you have your woofer wired to a single bxi2608?a quad 2 ohm woofer can only be wired to 2 or .5 ohms... which a bxi2608 puts out its most power at 1 ohm nominal.
April 3, 201015 yr Author may i ask how you have your woofer wired to a single bxi2608?a quad 2 ohm woofer can only be wired to 2 or .5 ohms... which a bxi2608 puts out its most power at 1 ohm nominal.It is hooked up to my amp at .5 ohms. All pos to pos and all negs to negs the amp can handle it fine but im sure if I had 2 dual 2 ohm subs wired down 1ohm each then to .5 ohms both together it would prob be shutting off bc of all the resistance from both magnets. but one magnet does not create enough energy to hold back my bxi. I think I need to find me a better box. it is hella loud boud I am just trying to get a little bit more out of it.. you may email me if you want. I have a hard time on this site I could not hardly find my post again lol [email protected]
April 22, 201015 yr may i ask how you have your woofer wired to a single bxi2608?a quad 2 ohm woofer can only be wired to 2 or .5 ohms... which a bxi2608 puts out its most power at 1 ohm nominal.It is hooked up to my amp at .5 ohms. All pos to pos and all negs to negs the amp can handle it fine but im sure if I had 2 dual 2 ohm subs wired down 1ohm each then to .5 ohms both together it would prob be shutting off bc of all the resistance from both magnets. but one magnet does not create enough energy to hold back my bxi. I think I need to find me a better box. it is hella loud boud I am just trying to get a little bit more out of it.. you may email me if you want. I have a hard time on this site I could not hardly find my post again lol [email protected]That made no sense what-so-ever?
April 22, 201015 yr may i ask how you have your woofer wired to a single bxi2608?a quad 2 ohm woofer can only be wired to 2 or .5 ohms... which a bxi2608 puts out its most power at 1 ohm nominal.It is hooked up to my amp at .5 ohms. All pos to pos and all negs to negs the amp can handle it fine but im sure if I had 2 dual 2 ohm subs wired down 1ohm each then to .5 ohms both together it would prob be shutting off bc of all the resistance from both magnets. but one magnet does not create enough energy to hold back my bxi. I think I need to find me a better box. it is hella loud boud I am just trying to get a little bit more out of it.. you may email me if you want. I have a hard time on this site I could not hardly find my post again lol [email protected]That made no sense what-so-ever?Nice first post!
