About how much airspace will an RL-p take up if inverted? Is it basically ZERO (less than .05) or is something measurable?
Thinking of inverting these babies, box design pends this question.
I haven't myself worked with inverted enclosures, but you might in fact be adding a slight amount of volume to the enclosure on account of the deep cone that is now protruding out of the box rather than intruding into the box! I imagine exact volume will require you to take your own measurements since it could also vary depending upon your mounting style (extra baffles, etc).
My bad man :-D, yup both are here and look fine. Though I scrated the cone on of them, :(:(.
Would there be any safe way of taking off the black paint and having the polished aluminum?
I don't recommend trying to remove the paint.
You would need a fairly powerful solvent and could risk the integrity of the surround if you get any on it.
There are quite a few coats of paint on that thing, so it could get really messy if you try to remove 'em! :blink:
  • Admin
I would be interested in these inverted, would cut down on the enclosure size
