March 31, 201016 yr Please search first, and have a better question. Explain what you are curious about.
March 31, 201016 yr 1 watt will be enough to make it play. The 1500D or the 2000D is great for a BTL.
March 31, 201016 yr You could of just put this in your current post you have about subs, please provide more information and dont make ridiculous topics. There is no such thing as underpowering a sub so it doesnt matter the power as long as your not trying to double or triple the rms.
April 4, 201015 yr I'd run the amp at .5ohm assuming you're trying to get the most out of the sub and have the electrical to support the 1500 at that ohm load for daily...
April 4, 201015 yr I'd run the amp at .5ohm assuming you're trying to get the most out of the sub and have the electrical to support the 1500 at that ohm load for daily...Unless he is competing that wont really make that much of an audible difference to ear running that amp at 1 ohm versus 0.5 ohm but to each its own.
April 4, 201015 yr I'd run the amp at .5ohm assuming you're trying to get the most out of the sub and have the electrical to support the 1500 at that ohm load for daily...I'd skullfuck you if I could.OP: You need a minimum of 100,000 watts to even get the BTL to move!Seriously though? Do some research on drivers and their behavior at all levels of power input. There is NO minimum amount of power needed for ANY driver.
