Instead of cutting a hole for a terminal cup I plan on running a 1/4 inch or so bolt through the side of my sub box.
My question is, what type of bolt would be best for power/signal transfer?
-Standard Steel
-Stainless Steel
-Brass
-Aluminum
-Chrome
-Grade 8 Steel
-Copper (not sure I can find it)
There is just so many options and I don't know what to choose.
Thanks All :)
Do you want to spend on the money on it for the best? I will say anything on your list will do, but I wouldn't use the steel.
Money's not an issue. It's just a couple bolts :) Just looking for the best
Your best connection would come from running a wire straight to it from a little hole in the side. But not as removable then. But yes a copper bolt would be the best bet from your list.
I just use some stainless steel bolts I had laying around. Over the course of 1 inch, the resistance will be negligible between copper and steel.
x2
I got stainless steel for corrosion resistance, and the nice finish. I'll post pics when installed.
2 - 2" #10/24 Stainless Steel Bolts
6 - #10/24 SS Lock Nuts
4 - #10 SS Washers
4 - #8 Gauge Compression Terminals
I'm running 10 gauge speaker wire, but speaker wire is generally larger than standard power wire, hence the 8 gauge compression terminals.
Thanks for the input guys
