Posted April 30, 201016 yr I'm going to build a ported box for two and need to know if the ported box volume spec (0.6 cuft tuned to 30Hz) is net or gross.
April 30, 201016 yr Author Net. Its always that way.Thanks! In that case, do you happen to know the e8's displacement?
April 30, 201016 yr Net. Its always that way.Thanks! In that case, do you happen to know the e8's displacement?Not off hand but with a little search, you will find it in seconds.
