Posted May 1, 201016 yr Anyone have experience or opinions on Memphis amps?I'm considering a 5 channel to run some comps and a sub.What are Memphis comparable to?Thanks
May 1, 201016 yr Author I'm looking at the 16-MC5.700 It's rated at 55w x 4 and 400w to the sub.I saw a birth sheet and it said 100 x 4 and 600 x 1 Looking at either the DLS Iridium 6.2i or HAT Clarus 61-2 for the front and I have a single IDQ12 D4v3 for a sub. Edited May 1, 201016 yr by Mahna Mahna
May 1, 201016 yr I'm looking at the 16-MC5.700 It's rated at 55w x 4 and 400w to the sub.I saw a birth sheet and it said 100 x 4 and 600 x 1 That is a nice amp! Great for a nice daily set up!
May 1, 201016 yr I would say go with the SAZ 50.4 and we all know that one is underrated. And i think it is cheaper.
May 1, 201016 yr Author The birth sheet doesn't really mean anythingI thought the birthsheet is a confirmation of the actual power output?
May 1, 201016 yr Actually, they pull one amp off the assembly line and test it (it's not a very accurate test in the first place) and print what that amp produced and put it on all the amps for that run, that means hundreds of amps got the same paper with them.
May 1, 201016 yr The birth sheet doesn't really mean anythingI thought the birthsheet is a confirmation of the actual power output?More or less a marketing guesstimate gimmick!
May 1, 201016 yr I have no experience with Memphis amps actually, I've never heard bad things though.
May 1, 201016 yr I have always loved memphis amps. I have owned the 16-1000d and the Mojo 2000d and both were built like tanks. Both are kinda old school though. I havent ran any of their newer amps
May 1, 201016 yr The local audio shop I hang out at sells memphis. Id say they are pretty reliable, (even though my memphis belle 16st1300d has broke twice) They put out rated, don't know if it's changed over the years but older memphis amps have like .5% THD. Which is pretty terrible, don't know how much that matters though. I also know from experience that a jl 250/1 @ 2 ohms was louder on a meter than a memphis PR 500 @ 2 ohms Which blew my mind, since the PR allegedly puts out 300 rms @ 2 ohms.
May 1, 201016 yr I would say go with the SAZ 50.4 and we all know that one is underrated. Actually, nobody here knows that as it's never actually been demonstrated or proven. don't know if it's changed over the years but older memphis amps have like .5% THD. Which is pretty terrible, don't know how much that matters though. That's not terrible....that's well below the threshold of audibility. Which means you won't hear a any difference between .5% THD and .000001% THD.
May 2, 201015 yr Memphis makes good amps, I had a Power Reference a few years ago. I loved my amp and it did its job, i accidentally wired to 0.5 ohms and it lasted for almost a year until it gave in (user error listening to a friend before knowing what I was doing). What is your budget and what features do you need. If the Memphis fits your budget and will fit the requirements for your install then get it.
May 2, 201015 yr I would say go with the SAZ 50.4 and we all know that one is underrated. Actually, nobody here knows that as it's never actually been demonstrated or proven. don't know if it's changed over the years but older memphis amps have like .5% THD. Which is pretty terrible, don't know how much that matters though. That's not terrible....that's well below the threshold of audibility. Which means you won't hear a any difference between .5% THD and .000001% THD.That's why I said I don't know Does the thd have anything to do with the signal being more likely to clip? (just trying to learn)
May 2, 201015 yr The local audio shop I hang out at sells memphis. Id say they are pretty reliable, (even though my memphis belle 16st1300d has broke twice) They put out rated, don't know if it's changed over the years but older memphis amps have like .5% THD. Which is pretty terrible, don't know how much that matters though. I also know from experience that a jl 250/1 @ 2 ohms was louder on a meter than a memphis PR 500 @ 2 ohms Which blew my mind, since the PR allegedly puts out 300 rms @ 2 ohms.i agree they break easy my friends amp broke, when he took it to the audio shop were he bought it they told him that it broke because the vibration and warranty didn't cover that
May 2, 201015 yr That's why I said I don't know Does the thd have anything to do with the signal being more likely to clip? (just trying to learn)No.
May 2, 201015 yr I would say go with the SAZ 50.4 and we all know that one is underrated. Actually, nobody here knows that as it's never actually been demonstrated or proven. don't know if it's changed over the years but older memphis amps have like .5% THD. Which is pretty terrible, don't know how much that matters though. That's not terrible....that's well below the threshold of audibility. Which means you won't hear a any difference between .5% THD and .000001% THD.That's why I said I don't know Does the thd have anything to do with the signal being more likely to clip? (just trying to learn)Here is a good read on amplifiers, I had to re-read it again in order to learn ..... Anatomy of the Power Amplifier, By Robert Zeff - SSA Car Audio Forum
May 2, 201015 yr thanks for the link to the good read........reading about the classes of amps makes me wonder how a "BD" amp works.....
May 3, 201015 yr I had an ST-1000D about 6-7 years ago. It was my first big sub amp. It did the job pretty well. I read a review by a car audio magazine and it didn't quite do rated power, like 962 watts and at a decently high THD as has been said. But will that matter on subs? No. It seemed to be pretty solid overall. I'd say they're about average. Obviously better than the Legacy/Pyle stuff, IMO slightly better than Hifonics, but I like my Sundown better.
