Posted May 5, 201015 yr Is 12gauge speaker wire sufficient for running a saz-1500d to sa12s. I'll be running the amp at 1ohm.Speaker wire is about 4feet in length. If it can't handle that much power then can I just double it up and run two strands for each positive and another two for the negative.
May 5, 201015 yr So assuming you are running (2) D4 subs and ~1800 watts from that amplifier, 12 ga is more than enough.
May 5, 201015 yr 10-14 gauge wire will do fine for subwoofers but you can go bigger if you want to, just a preference thing thats all.
May 6, 201015 yr Unless you're after all out SPL, there's no gain to be had running something bigger then 12 gauge.
May 6, 201015 yr Author Unless you're after all out SPL, there's no gain to be had running something bigger then 12 gauge.i'm not competing or trying to raise it a couple db's
May 6, 201015 yr All I have is 4 8 0 and double 0 lol. I run 8. But its really not needed just what I had at the moment.
