Is 12gauge speaker wire sufficient for running a saz-1500d to sa12s. I'll be running the amp at 1ohm.
Speaker wire is about 4feet in length. If it can't handle that much power then can I just double it up and run two strands for each positive and another two for the negative.
12 is fine if you have nothing bigger :drink40:
So assuming you are running (2) D4 subs and ~1800 watts from that amplifier, 12 ga is more than enough.
okay thanks guys, one less thing I need to buy at the moment :P
10-14 gauge wire will do fine for subwoofers but you can go bigger if you want to, just a preference thing thats all.
Unless you're after all out SPL, there's no gain to be had running something bigger then 12 gauge.
i'm not competing or trying to raise it a couple db's :P
All I have is 4 8 0 and double 0 lol. I run 8. But its really not needed just what I had at the moment.
