Posted May 18, 201016 yr I´m not so god at english too start with cause im from Sweden! =)i´ve just bouht a saz-3500d and i´m wondering if i can load it down too 0.5ohm?At the moment im using it on 4 Audiotop 15.4 15" subs,and i had an Sundown 3000d before and the difference in preassure was really big and with the saz3000d i played 150.00 with music. But i´vw also bougt 2 Sundown nightshade 12" 2 * 2 subs and my otehr question is there any chance that i can play more than 150 db with the 2 Nightshade on the 3500d amp?
May 18, 201016 yr welcome!i wouldnt wire it down that low, im pretty darn sure it voids the warranty on the amp. but its up to you of course a 150 COULD be done, it just depends on the install/vehicle/tuning/yada yada yada.
May 18, 201016 yr Author Thanks! =)Ok but i have run my 3000d in 0.5 ohm and it was not any problem.I had 2 WMD2 18" before and i load the amp with 0.5 on theese.I have 4 Banner runnig bull 95ah batteries do you think that would be enougtfor the 3500 amp?
May 18, 201016 yr if you have the electrical to back it up you can run at .5 ohm, you just lose the warranty when you do that. dont expect jacob to fix it when it breaks. and i dont know what a 4 banner is or bull batteries.
May 18, 201016 yr Author if you have the electrical to back it up you can run at .5 ohm, you just lose the warranty when you do that. dont expect jacob to fix it when it breaks. and i dont know what a 4 banner is or bull batteries. ok so you dont have banner batteries in us?Running Bull | Banner Batterien
May 18, 201016 yr If you ran the 3000D with no problems at 0.5ohms then you will be fine with 3500D just make sure you have to electrical to keep the voltage up. How many db's you want to hit will all be install dependent, with 2-12" Nightshades and 3500 you could get or come close or surpass it but it all depends. Good luck and hope this helps.
