Hi all. I'm about to order a btl 15 d2 with cooling, I heat ring, and high Xmax coil. I have a hifonics bxi2010d. I came up with this box design, but I want to make sure I haven't overlooked anything important. Will I get port noise or any other bad stuff?
Its for the trunk of a 97 ford thunderbird. With the current design I have, the box would be lying with the port and the sub facing up toward the rear deck. I could change the dimensions slightly, any comments or suggestions would be appreciated.
EDIT: link to image was broken
Edited by Spaz
Thanks for the reply, and the higher tuning is because of the subwoofer displacement right? I didn't realize it changed it so much. Maybe a tune closer to 31hz would get me closer to 33hz after sub displacement?
Thanks a bunch for the info, I really appreciate it
