Posted May 24, 201015 yr I am no electrical pro, and I've always wondered, is there a huge difference in have a 1 ohm sub and a 2 ohm sub? Edited May 24, 201015 yr by LuckyChalmz
May 24, 201015 yr Unclear on the question, but there is 1 ohm of difference between 1 ohm and 2ohms. Not a real big difference.
May 24, 201015 yr Author Unclear on the question, but there is 1 ohm of difference between 1 ohm and 2ohms. Not a real big difference.I guess I should've been a little more clear, I meant output of the subwoofers, like would they sounds better, hit harder, etc.
May 24, 201015 yr Same clean power at 1 or 2 ohms, or any load for that matter, there will be no difference to the ear.
May 24, 201015 yr Author Same clean power at 1 or 2 ohms, or any load for that matter, there will be no difference to the ear.Thank you.
May 24, 201015 yr So let's say I have a D1 ohm sub wired to 2 ohms on an amplifier that delivers 1000 watts at 2 ohms, then I switch it out for a D2 ohm sub and wire it to 1 ohm and put it on an amp that does 1000 watts at 1 ohm, do you think there would be any difference?
May 24, 201015 yr Author So let's say I have a D1 ohm sub wired to 2 ohms on an amplifier that delivers 1000 watts at 2 ohms, then I switch it out for a D2 ohm sub and wire it to 1 ohm and put it on an amp that does 1000 watts at 1 ohm, do you think there would be any difference?Well, by reading what you said I am guessing since they have the same amount of wattage being distributed to the subwoofer, I would say no there shouldn't be any difference.
May 24, 201015 yr Only difference would be the amp would put out more at 1ohms then 2ohms your ear wont ear any SQ difference only loudness of pure BASS!
May 24, 201015 yr Only difference would be the amp would put out more at 1ohms then 2ohms your ear wont ear any SQ difference only loudness of pure BASS!That's dependent on the amplifier.
May 24, 201015 yr Only difference would be the amp would put out more at 1ohms then 2ohms your ear wont ear any SQ difference only loudness of pure BASS!That's dependent on the amplifier...Ok lets get more specific "MAJORITY" of amps put out more at lower ohms.
May 24, 201015 yr Author Only difference would be the amp would put out more at 1ohms then 2ohms your ear wont ear any SQ difference only loudness of pure BASS!That's dependent on the amplifier...Ok lets get more specific "MAJORITY" of amps put out more at lower ohms.Lol, okay question is do SAZ-1500D's put out more at lower ohms? And can 12" XCON's D2's handle the output? Edited May 24, 201015 yr by LuckyChalmz
May 24, 201015 yr Only difference would be the amp would put out more at 1ohms then 2ohms your ear wont ear any SQ difference only loudness of pure BASS!That's dependent on the amplifier...Ok lets get more specific "MAJORITY" of amps put out more at lower ohms.Lol, okay question is do SAZ-1500D's put out more at lower ohms? And can 12" XCON's D2's handle the output?If you'd do a little research, you could answer all your own questions, and probably feel better about doing it.Here is a little something to get you started:Sundown Audio - SAZ-1500DSound Solutions Audio - XCON Series Subwoofers
May 24, 201015 yr Author Only difference would be the amp would put out more at 1ohms then 2ohms your ear wont ear any SQ difference only loudness of pure BASS!That's dependent on the amplifier...Ok lets get more specific "MAJORITY" of amps put out more at lower ohms.Lol, okay question is do SAZ-1500D's put out more at lower ohms? And can 12" XCON's D2's handle the output?If you'd do a little research, you could answer all your own questions, and probably feel better about doing it.Here is a little something to get you started:Sundown Audio - SAZ-1500DSound Solutions Audio - XCON Series SubwoofersI understand what your saying, and I respect that, but isn't that what a forum is for to ask questions and receive answers? Yes you did give me and answer of your choice but still, either way rather I find it out myself or you or someone else tell me I end at the same spot, with the same knowledge.Edit: Reguardless you led me to my answer to my question, and I thank you for that sir. Nothing wrong with showing me the door, and not opening it for me lol. Edited May 24, 201015 yr by LuckyChalmz
May 24, 201015 yr Dude, you know how many times this has been said or talked about? It gets tiring to tell people about ohm loads and how much a certain sub can take. Forums are for when you cannot find your answer by yourself or don't even know what to search for. But you do know the forum has a search feature too right?
May 24, 201015 yr Author Dude, you know how many times this has been said or talked about? It gets tiring to tell people about ohm loads and how much a certain sub can take. Forums are for when you cannot find your answer by yourself or don't even know what to search for. But you do know the forum has a search feature too right?Yes, I knew this. I know what you mean, most of the questions I ask is because I need reassurance to be certain lol. So my bad man. Edited May 24, 201015 yr by LuckyChalmz
May 25, 201015 yr I am no electrical pro, and I've always wondered, is there a huge difference in have a 1 ohm sub and a 2 ohm sub?If the amp has a really good power supply, and it's not a regulated output, you should see double the output going to half the load. In reality, some amplifiers have a regulated output so they produce the same power at both 1 and 2 ohms, while others just don't have the power supply to support that sort of load so they only put out maybe 60% more power at 1 ohm over 2 ohms.That said, the electrical differences on paper anyway would be higher distortion (THD) and lower S/N ratio, worse damping factor and less dynamic headroom and reserve power.Will you actually be able to hear these things? Very doubtful.
