Posted June 7, 201015 yr best options for SQ and i wanna hit some lows. the amp will be a SAZ-1000D dual 1 or dual 2?hyper pole yes or no?cooling yes or no?flatwind yes or no?daily of spl?universal yes or no?
June 7, 201015 yr Those options won't make it "sound" any different. coil configuration is for the amp you want to use. Get dual 2 ohms for a 1 ohm load to the amp for 1000 watts. Get daily option as you don't want to just do SPL. Read up on what the others mean on fi's tech.
June 7, 201015 yr ok from what ppl tell me i dont know shit...but here goes....for 1 sub dvc 1 ohm can be hooked up at 0.5 ohms or 2 ohms 1 dvc 2 ohm sub can go 1 ohm or 4 ohm...2 dvc 1 ohm subs can be 1 ohm or 4 ohmsand 2 dvc 2 ohm subs can go 0.5 ohms or 2 ohmsthat being said i think you wanted to run a 1 sub setup...so since most amp put out peak power at 1 ohm.....not all....just most....you would want a dvc 2 ohm sub......as far as the options goif you want to listin to music is have to pick daily....hyper pole helps to get the sub cool and comes with the cooling option...so only pick the cooling option there....the flatwind will help the sub handle more power...and universal will give you the option to change your sub from 1 - 2 ohm dvc...but you will have to pay fi to do it each time if im not mistaken
June 7, 201015 yr Author Those options won't make it "sound" any different. coil configuration is for the amp you want to use. Get dual 2 ohms for a 1 ohm load to the amp for 1000 watts. Get daily option as you don't want to just do SPL. Read up on what the others mean on fi's tech.ok thanks
June 7, 201015 yr Author ok from what ppl tell me i dont know shit...but here goes....for 1 sub dvc 1 ohm can be hooked up at 0.5 ohms or 2 ohms 1 dvc 2 ohm sub can go 1 ohm or 4 ohm...2 dvc 1 ohm subs can be 1 ohm or 4 ohmsand 2 dvc 2 ohm subs can go 0.5 ohms or 2 ohmsthat being said i think you wanted to run a 1 sub setup...so since most amp put out peak power at 1 ohm.....not all....just most....you would want a dvc 2 ohm sub......as far as the options goif you want to listin to music is have to pick daily....hyper pole helps to get the sub cool and comes with the cooling option...so only pick the cooling option there....the flatwind will help the sub handle more power...and universal will give you the option to change your sub from 1 - 2 ohm dvc...but you will have to pay fi to do it each time if im not mistakenok so i will get dual 2 ohmcooling flatwinddaily
