  • Admin
Got to the gym, decided on weights and went 3 x 12/10/8/6 HEAVY. I miss lifting heavy. But I am hungry!!!
  • Replies 601
  • Views 61.6k
  • Also, I found a decent page with various exercises. Exercise & Muscle Directory
  • not being judgemental but just giving advice. the reason some of you are having trouble gaining size/strength is that it seems you're doing the crap muscle&fitness ect tells you to do. that stuff
  • Aaron Clinton
    Aaron Clinton
    2/7: standing shoulder press / shrug - 5 supers treadmill - 15m 90% seated cable row - 4 2/8: decline press - 5 incline cable fly - 5 elliptical - 15m - 75% dips - 3 crunches - 100 2/9: bent bar curl/
  • Admin
1.5 miles last night at a 9:33 pace. I guess I am working on speed, then switch back to endurance, then back....
  • 2 weeks later...
  • Admin
Again, not an actual workout, but hour of raking leaves as fast as I can before the Ravens game, and then an hour of chopping down and cutting up branches. Upper body is well tired out.
  • Admin
Raked leaves at a hardcore pace for 2 hours in the freezing wind. :turkey:
Was going to hit the gym but instead got woken up for a piss test.
J
  • Admin
Aaron Houston Clinton: First run fueled by positive energy instead of negative.
iMapMyRun
Completed (Run): Distance 2.53 mi, Duration 28:22, Pace 11:12 min/mile, Speed 5.4 mph.
  • Admin
Been doing all sorts of high rep band exercises while watching the Terps beat up on Penn State.
Did around 80 Cruches, 50 Pull-ups in variations, around 90 push-ups, and finished off doing barely 20 paces, I think it was about 25m one way.
  • Admin
iMapMyRun
Completed (Run): Distance 2.06 mi, Duration 22:08, Pace 10:46 min/mile, Speed 5.6 mph.
Freezing cold, but pushed through.
iMapMyRun
Run Mr. Volcano! Run!
  • Admin
iMapMyRun
Hahaha, thanks. Below 40 degrees is brutal on the new knee, but I have to exercise and get my cardio back up. My pace is still poky from my standard, but slow is better then nothing at this point. Now if I can go during day light, it would make a world of difference, in terms of temperature and distance I can go. The right leg is not back to even 60% yet, but feels strong enough to make it through a 5k no problem.
  • 2 weeks later...
  • Admin
Did 1.5 miles at 9pm last night in 18 degrees. Was brutal, but I was not out for exercise.
2.2something miles, 300 cal, 38 carbs plus upper body weight lifting; stamina is finally increasing
  • Admin
Only did 5 push ups yesterday.
  • 1 month later...
walked the pups around the whole neighborhood in addition to 200 cals on the treadmills plus weights and I'm starting to add basic calisthenics in to my normal routine; mostly jackknives and crunch/crunch variations
  • 2 weeks later...
  • Admin
Ok, starting to get settled (sort of). Switched gyms. Back to the power lift and eating like a freak. Do it!
Today:
Cable flies
Flat bench dumbbell press&flies
Incline dumbbell flies
10 minutes treadmill - 50% pace.
All free weights between 6-8reps of maxing out each set! BULK up time!!!!!!!
Bicep day
Chest day
Tricep day
All around legs day....
Cardio day!! interval running jog/Sprint trying not to loose muscle on cardio.
Supplements Multi vitamins, Amino acids, Creatine(Con-cret), Pre workout (Methly Mass) dont forgot the most important thing your food red meat and protein!!!!!!!!!
  • Admin
Today:
Spread cable lat pull downs
Standing bar bell curls
Seated individual lat row
Standing cable single arm curls
1 mile on treadmill, no pain, 65%.
