Posted September 13, 200521 yr how many watts can thse subs handle?its only singe voiice coil 3.5 can the sub produce 1 ohms
September 13, 200521 yr no, the sub will not be able to be wired to 1 ohm...it's rated for 1000wrms.wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
September 13, 200521 yr Author 1000 watts on 15?how many watts can the 12 handle?can the 12 inch be safe on a 3.2 cu ft port box on a 1500 watts ampcan it handle 1500 watts on the 12?will there be a DVC model?
September 13, 200521 yr 1000 watts on 15? rated, yes.how many watts can the 12 handle? same as the 15can the 12 inch be safe on a 3.2 cu ft port box on a 1500 watts amp depending upon port area, this box is just about the perfect sizecan it handle 1500 watts on the 12? more then likely. properly set gains, with the proper enclosure will determine this. will there be a DVC model? not yet. tc sounds is still working on that. my answers are in red above...wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
September 13, 200521 yr Author mrray....i have a 2 channel alphasonik amp 1400watts@4ohms can this amp handle 3.5 ohms....the port tuning is 32hzey man what the difference on low and high vent tuning...by the way do u like the GAME
September 13, 200521 yr mrray....i have a 2 channel alphasonik amp 1400watts@4ohms can this amp handle 3.5 ohms.... yep, it should be fine.the port tuning is 32hz that 's sound really good! but how big is the port? ey man what the difference on low and high vent tuning...low tuning=sounds better...high tuning= more output. not set in stone, but the general rule. with that box/tuning/sub/power...u'll sound really good and be plenty loud..lolby the way do u like the GAME long joke here at ssa..lolanswers in red......again...lol..wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
September 13, 200521 yr 4 some reason i think the rl-s12 is going to stomp a mudhole in 12w7 or even the 13w7 in sq and output80
September 13, 200521 yr Author pls help me to configure this sub box to achieve 28hz vent tuning the size is perfect i just want the port to be reconfigure to produce 28hzthankspls dont make the box bigger or smaller just adjust the port to produce 28hz..the box size is perfect for my trunk...thanks
September 13, 200521 yr pls help me to configure this sub box to achieve 28hz vent tuning the size is perfect i just want the port to be reconfigure to produce 28hzthankspls dont make the box bigger or smaller just adjust the port to produce 28hz..the box size is perfect for my trunk...thanks<{POST_SNAPBACK}>This is a forum not a concierge. And changing the port size to give you that lower tuning will alter the cube of the box not to mention the displacement of this monster. If you want to learn then read up and ask for help. If you want someone to do the work for you ante up. Effort goes a long way....plus these guys work for a living and have bills to pay.
September 14, 200521 yr sure these subs can be wire to 1 ohm.....but you need more than 1. <{POST_SNAPBACK}>Nominally, still impossible.
