Posted June 30, 201016 yr Trying to wire up now- not worried about what ohm to wire it up to got thati got 3 and i am wiring it to 1.33 ohmsand i was gonna just use the wire terminal as a jumper to get the neutral and power wire to the other subs like 2 wires on the terminals on 2 of the subs and the last sub will just have 1 wire into all the terminals because i dont have to jump it on the far end so my question is can two 12 gauge wires fit in one of the terminal in the sa8-- if not would it be better to run a seperate run for each speaker to where the wires are coming into the box- or would wire nutting them and getting a good tape job be good enoughcant wait to try these out-to make sure my box is good so i can put the evercoat rage on and wrap it up so i can be bumping againthankskevin Edited June 30, 201016 yr by klee7013
June 30, 201016 yr You can actually go smaller when wiring from terminal to terminal.I actually like to wire each + and - to the binding posts themselves.
June 30, 201016 yr just cut some strands off the 12 gauge so it fits in the terminal. no need to buy smaller wire..
