Posted July 1, 201015 yr Ok im gona buy a new amp and every time i go online reserching i find this amp's like the "Lanzar MAXP2960" real cheap under $200. WHy is this? are these amps way under power, and if so about how many rms watts is it;.Lanzar MAXP2960Lanzar MXA254Boss PH2.1500Lanzar VBP281Lanzar VBP261Power Acoustik BAMF-2600/2 (BAMF2600/2)Lanzar MXA282SPL FX2-2600Autotek AT2000.1Are any Good i was thinking about buying oneHELP PLZ
July 1, 201015 yr Personally I would stay away from those. Mostly bling and over inflated specs.Look into the "For Sale/Wanted" section for some good used quality amplifiers.
July 1, 201015 yr OldSkool_08 I meen 98GMC would not misinform, try the for sale section lots of good deals show up there. I got a Sundown 1200D for $275. Good Luck!
July 1, 201015 yr x2 on that, I'd get any used quality amp before those. I got a used saz-1500d for $315!!!
July 1, 201015 yr Can also check out dB-r for some refurbished Sundown Amplifiers Refurbished Amplifiers : dB-r Electronics, Online Store
July 2, 201015 yr I looked at lanzar amps for a while, but I decided against them because they did not seem to be all that well reviewed, and not many people have them to review them
July 2, 201015 yr Author x2 on that, I'd get any used quality amp before those. I got a used saz-1500d for $315!!! i will give you $200
July 2, 201015 yr x2 on that, I'd get any used quality amp before those. I got a used saz-1500d for $315!!! i will give you $200uh no?
July 2, 201015 yr If you don't want to buy a used amp, save some more money !Those amps you have listed don't seem to be good enough.
July 2, 201015 yr If you want to stay under 200 then you can get a audiopipe ap15001d for 150 or an audiopipe ap18001d for 190.
July 3, 201015 yr The only lanzar I'd get is an opti drive.x2. Stay away from all the stuff in your first thread. None are quality.
July 3, 201015 yr If you want a decent amp for a great price check out Audiopipe. They are much better than Lanzar, Legacy, Pyramid, Boss, and all those insanely overrated amps. NEW! AUDIOPIPE 1500W MONO Car Audio Amplifier Amp Sub - eBay (item 390188564940 end time Jul-26-10 13:20:44 PDT)165 shipped(edited).3000 WATT CAR AMP AUDIOPIPE CLASS-D 1 CHANNEL MONO - eBay (item 140421574327 end time Jul-27-10 16:19:48 PDT)329 shipped.I have the AP15001d and it works well with my FI BL 12. Does rated power on 14.4 volts. You can check them out and all the internals if you do some research. Edited July 3, 201015 yr by FI-Soon2B-SSA
July 4, 201015 yr Audiopipe AP series, best budget amp around! I own an AP15001D and couldn't be more satisfied. Don't know what your thinkin for subs, but their Eye Candy line of subwoofers is pretty decent as well. There are 2 people around here that are using the TXXAP15's and doin 145+. Checkout vminnovations.com for Audiopipe gear, they are an authorized dealer. Good luck.
