Posted July 7, 201016 yr Any idea on what kind of power I could expect out of the 2500 at 18 volts wired down too .25?
July 7, 201016 yr Any idea on what kind of power I could expect out of the 2500 at 18 volts wired down too .25?on burp right?
July 7, 201016 yr Author Any idea on what kind of power I could expect out of the 2500 at 18 volts wired down too .25?on burp right?Yes sir
July 7, 201016 yr Any idea on what kind of power I could expect out of the 2500 at 18 volts wired down too .25?on burp right?Yes sirIt all depends on impedance rise.
July 7, 201016 yr Author Ok, will it play at 18 volts at .25 ohms tho with out going straight into protect?
July 9, 201016 yr it totally install dependent man, its a stout amp and will do a lot in the right hands
July 9, 201016 yr On 12v Derrick was able to get over 3300 out of it at 0.25 ohms -- typically on 18v they get alot more touchy at 0.25 -- I have tested the other SAZ line amps as such successfully with a roll. Just haven't had my 18v system back together to test the 2500 yet.
