I have two AQ 12's in a ported box. One of the subs messed up so I'm deciding to upgrade.
Will the Fi ssd 12's work in the same box as the AQ's?..
The box I think is about 4.0 cuft.
thanks for any help.
HDC or SDC from AQ?
Box dimensions and port dimensions will also help.
They're SDC
Dimensions are 27x14hx32L
Ported with two 6" aeros
There is also a length associated with a port.
I believe they're 17" long.
Bump.
Would appreciate an answer.
Thanks.
What is the tuning frequency
OK, thanks for all your help..
Hopefully I can still get a reply here.
But I was mistaken on the cu ft.
It's 5 cuft and tuned to about 35-37 hz.
So would I be able to use two ssd's
I could always tune it lower since they're aero's
Edited by Boogie
