Posted July 22, 201016 yr I plan on getting/installing these things.1 FI btl 15270amp HO ALTPower Acoustik ovn1-5500dbig 3 upgradeWas wondering which batteries i would need to get if any.Also was wondering if the stock alternator would do ?This will be for daily use no spl comps.Any other questions ask me please.
July 22, 201016 yr The only way to tell if the stock alternator will do is for you to install and start playing your music and see if it holds up. If you dont have the money for an alternator and you want to buy batteries first then go for it but a alternator will be best first electrical upgrade I would do if cash was right. Make sure you do the Big 3 as well.Here's a start:
July 22, 201016 yr Author Stock alt is 125amp.Should i go for the dual 1 or dual 2ohm setup with the amp im getting?The system i have now is 2 FUBR 12's with a bamf 2000/1d Edited July 22, 201016 yr by chevyfan
