Posted July 30, 201016 yr whats going on ppl? i have a 15" bTL with all the options just wondering the most RMS i can send to the sub at 1ohm? the required 2000rms or could it handle more since it's fully loaded?
July 30, 201016 yr 2000wrms. more if your smart and have good equipment. i say if you have to ask, you should stick to 2000wrms
August 1, 201016 yr Jeez....more post make you more of a man?^Its listed on the company's site 2000 rms, it can take more or less and be fine but be smart. Edited August 1, 201016 yr by keetykush
August 1, 201016 yr Jeez....more post make you more of a man?^Its listed on the company's site 2000 rms, it can take more or less and be fine but be smart.x2Off Subject OP,Michigan FTW! I lived in Detroit for 16 years.
August 1, 201016 yr Author 2000wrms. more if your smart and have good equipment. i say if you have to ask, you should stick to 2000wrmsoh ok thanks man appreciated
August 1, 201016 yr Since when is the RMS power rating a "requirement"?This isn't even remotely true......
August 2, 201016 yr While people use more than the rated power, its not something as a manufacturer that we recommend. The more power used, the less room for error there is in setup. Normal blabbering.... no bass boost on headunit or amp, set gains correctly with respect to headunit output voltage, set subsonic filter 3-4 Hz below tuning for 18-24db/oct filters and 2-3 for 12dB....Thanks,Scott
