Posted August 3, 201016 yr What tools and methods do I need to calculate my imp rise. 1 15" AA SMD, Sundown saz 3000d. 4^3 @ 31hz, 30^2 port area (I know way to small, just testing an aeroport). Sub wired to .75 ohmJust got a clamp meter today and messing around I did 18.4 amps & 79.8 volts @ 37hz. I want to know what the impedance is doing but not exactly sure how to check for thatThanks
August 3, 201016 yr 4.337 ohmsPlay through the frequencies taking voltage and current measurements for each, then use ohms law to calculate impedance R=V/I. R= Resistence/impedance V = voltage I = Current.
August 4, 201015 yr Author That equation fried my brain instantly but I'm gonna take another look and work w/ it.Going from .75 ohm to 4+ ohm, f**kin sucks! Imma have to work on thatThanksAnyone else know of another way lmk
August 4, 201015 yr .75 is your DCR and has little to do with the box impedance....There is no such thing as "impedance rise". This term is a wrong way of describing what happens. You have an imedance curve or plot. This both rises and falls... Hence "rise" is not accurate. The biggest thing that effects your impedance curve is your box resonance and tuning. 10 or so Hz in either direction and your impedance can easily shift 2-4x either up or down....This is also why it is completely pointless to set your gain with a DMM when you have no idea what the impedance is....
August 4, 201015 yr Here is another read on the so called "Impedance rise myth"http://www.soundsolu...impedance-rise/
