Posted August 12, 201016 yr Does it really matter what RCA cables you use from your headunit to your amp?
August 12, 201016 yr Does it really matter what RCA cables you use from your headunit to your amp?I've used cheap $10 RCA's from radioshack without a problem. I think the only real variance in RCA cables is shielding\twisted pair, you might get some ground feedback\distorted signals but I doubt it.. Edited August 12, 201016 yr by Mr. Bojangles
August 12, 201016 yr Does it really matter what RCA cables you use from your headunit to your amp?I've used cheap $10 RCA's from radioshack without a problem. I think the only real variance in RCA cables is shielding\twisted pair, you might get some ground feedback\distorted signals but I doubt it.. x2, I have used cheap ones and expensive ones (both do the job). I got cheap ones at first to hold me over to get better quality ones and didnt notice a difference really (just personal preference really).
August 13, 201016 yr Does it really matter what RCA cables you use from your headunit to your amp?I've used cheap $10 RCA's from radioshack without a problem. I think the only real variance in RCA cables is shielding\twisted pair, you might get some ground feedback\distorted signals but I doubt it.. Complete myth. The only time you will get interference is with a 15 year old HU with low output voltage, or a bad ground, normally the latter.
August 13, 201016 yr monoprice rca or python rca from ebay. cheap and good insulation so it doesn't rip so easy. I hate those weak ass kicker twisted rcas. They ripped apart so easy.
