Posted August 15, 201016 yr how much battery do i need for a 1500w rms amp? what about if i bridged two amps so 3000w rms? will one kinetic hc2400 cut it? Edited August 15, 201016 yr by whatnow275
August 15, 201016 yr i am so confused right now, what does the name of this thread do with your question?
August 15, 201016 yr I was thinking the same thing about title! I think either Kinetic or XS has something on there website that helps with this very question. You input the watts and they will say what is needed, or well suggested.
August 15, 201016 yr I was thinking the same thing about title! I think either Kinetic or XS has something on there website that helps with this very question. You input the watts and they will say what is needed, or well suggested.Cell Calculator
August 15, 201016 yr Author i am so confused right now, what does the name of this thread do with your question? i felt like a dumbass, so i edited :/
August 15, 201016 yr Maybe you should start a different thread stating your problems and questions. to the original question( before you edited it)... yes the Fis will probably be louder than your kickers, you will need atleast an extra battery and yes build a new custom box.
