My next build will consist of 4 SA-8's with whichever coil options I need to see either a 1 ohm or 2 ohm final imp. Box will be 2.4^3 net tuned to 32Hz subs up port back. I already have an AP15001D so I could get a second and make an AP30001D. Would be cheaper than the AQX2500.1, but I don't know if the 8's will take 750 a piece daily. I know the AQX2500.1 would be pushing it already.
I have ran double rms to an AA Chaos 15 with my AP15001D without any problems. So I know how to watch my system for signs of stress and properly control my volume and gain. Electrical will consist of 140 amp HO Alt, Optima Red Top under the hood, Big 3 in 1/0, 1 run of 2/0 positive from front to back, 100ah in the trunk with 2/0 ground and 1/0 running to the amp.
Can someone who has ran the 8's on this much power please offer me some advice. Thanks.
My only problem wasn't really the power it was over excursion.I think if your carefull you can run 3k as long as they are in a small box. I had 3 cubes at 30hz and 3000w and two seperated spiders.
Yea I figured 2.4 after displacements would be ideal for so much power. I will definately have the ssf set correctly as well.
I run 1500 to two.
All newer SA-8s also feature the bolted down spider.
lol what?
