Looks good so far. :popcorn: Cant wait to see the finished product.
  • 2 weeks later...
Personally i would have probably doubled the port area, but it should be a sick setup anyhow. What kind of amp are you running?
  • 2 weeks later...
Looks good man! I'd probably put more port area in mine but it still looks good! Also, if you have the tools available I recommend rounding off the end of the port area with a router or something. Helps with the port noise :P
Bracing is good to if you wanna be troubled for it, and doubling the baffle is good as well.
I didn't realize I was gonna say all that. But hey, constructive critism for you :D
looks like a 1inch port you should have gone with 2.5 or 3inch in width
Box looks fine man. :)
And for all you people claiming "To small port"
If you would take into consideration the wood is .75" wide and the port is clearly larger then a single piece of MDF. Looks to me like it's at the very least 2.25" wide and as tall as the box is.
So with a 12" going into the box, it at the the least would be 13" in between the top and bottom layer of MDF.
So, 2.25 x 13" = 29.25^2 of port. More then enough.
The port will suffice, but more would not hurt :)
