Posted August 27, 201016 yr I wanna know if I could build a 4th order bandpass box for 4 12" subs in the trunk of my cavalier? I have a Soundstream Rubicon 2500D amp and a Kinetic1200 under the hood and a 2400 in the trunk. Thought about something sort of like this but, not too sure it would work with being such a small trunk...Just need some help tryin to figure out if I should do it or not.http://sketchup.google.com/3dwarehouse/details?mid=5362d8048075cdd16b752e7529d36aed[/media] Edited August 27, 201016 yr by Mommazboy
August 27, 201016 yr Author Do you think it could work? I want it to get pretty low but not sacrifice and sound quality...
August 27, 201016 yr Author haha yea still kinda undecided about what subs though. right now i was thinkin 4 Kicker Comp(black with yellow stitching), but im still lookin into woofers.
August 27, 201016 yr Author Right now its 1 Kicker CVX 15 box is 4 Cubes tuned to 32 Hz. Hits nice and low and I can be heard a good ways away. Just thinkin bigger and better.
August 27, 201016 yr no... not enough room in the cav... get one good sub, put it in the proper enclosure, make sure there is room for the air to get around the sub box and such and enjoy the sounds it makes....
August 27, 201016 yr Author no... not enough room in the cav... get one good sub, put it in the proper enclosure, make sure there is room for the air to get around the sub box and such and enjoy the sounds it makes....I have seen your vids on youtube and build log on here, gotta say very nice work. I think I might just do 2 12's. Maybe AQ SDC2.5's. Seal off from the trunk and port through rear deck.
September 3, 201015 yr How much room is in the trunk? How big a box can you fit? I very seriously doubt that you will have room for a proper 4th order for 2 12s in that trunk.
September 6, 201015 yr Author How much room is in the trunk? How big a box can you fit? I very seriously doubt that you will have room for a proper 4th order for 2 12s in that trunk.I had built a box for a 15 HDC3 but had a kicker cvx 15 in temporary, built 16H, 34W, 32D and 8" Port about 5^ft and tuned to 33Hz. Thing got LOW and LOUD!! I loved it! but I sold the Kicker and the box to a friend of mine. I think im going to seal box from trunk, subs and port firing forward, tuned to 34hz on 2000rms. Even still the idea of a 4th order in a Cavalier all Trunk Setup keeps repeating in my mind. Do you think a 4th can be done with 2 SDC2.5 12's?
September 6, 201015 yr Could it be built? Sure. Would it fit in your trunk? Not very likely. You're talking about and enclosure that would probably fill the back end of a large SUV.
