Posted August 29, 201016 yr Hey sup fi, i just grabbed a re xxx 04/05 model and it was recently reconed i was trying to find out the specs/what was put in it since i am interested in getting another one reconed. Apparently it has integrated leads,stiffer spider, fullsized dustcap, and an original xxx vc. I was trying to figure out if that is just the standard recone with the leads option and spider option or if i need to ask for something imparticular. The guy who i got it from said it was done by scott at fi and he should remember him by name since he went to fi and dealt with scott while there i was hopin he was right but either way the guys name was treston rego
August 31, 201016 yr No clue there, he probably has a XXX recone with the integrated lead suspension on it..By full dustcap you mean it is dished like a bowl? Or is it a "Boob" style cap like we use on our subs?
September 1, 201016 yr Author lmao nah it aint the boob. the cone and the dustcap is one peice like the ones afta the boob one and its all black i was just wonderin cuz i also didnt see black dustcaps listed for xxx's
September 1, 201016 yr We generally do not send those dustcaps out...all of the recones are the "Boob" style caps instead of the full dish dustcap.If you order a recone I'll make note of it on the order that you want a dished style dustcap to match the other one.Just please let me know in advance if you do order one.
September 13, 201016 yr Author hey some more quick questions... when i get the recone done im probably only gonna be sending in a motor is that all good with you guys? i know its gonna need a basket and need to be coned. also can the sub be coned to a dual 1 ohm even if i dont send in a motor from a dual 1 ohm sub thanx for the help
September 14, 201016 yr Yes we have a D1 coil that will fit in there...not a problem.Just please make sure that you package it properly when you send it in to us.
September 15, 201016 yr You guys can make dish dustcaps for my SE's then just put like an Fi sticker or something? Because I don't really like the boob dustcap.
September 15, 201016 yr You guys can make dish dustcaps for my SE's then just put like an Fi sticker or something? Because I don't really like the boob dustcap.They'll be from Ascendant, if they fit the cone.
September 16, 201016 yr You guys can make dish dustcaps for my SE's then just put like an Fi sticker or something? Because I don't really like the boob dustcap.They'll be from Ascendant, if they fit the cone.Like the Havoc or just flat black? need some more info. and pics if possible. Well its a 3 inch coil. And scott designed the SE' so im pretty sure he knows everything else. Edited September 16, 201016 yr by cheese20323
September 16, 201016 yr You guys can make dish dustcaps for my SE's then just put like an Fi sticker or something? Because I don't really like the boob dustcap.They'll be from Ascendant, if they fit the cone.Like the Havoc or just flat black? need some more info. and pics if possible. Well its a 3 inch coil. And scott designed the SE' so im pretty sure he knows everything else.A flat black full dish dustcap.
September 16, 201016 yr like the havoc yes, only its solid black it looks goodany pics I would get it and put an Fi, or AA sticker Edited September 16, 201016 yr by cheese20323
