let's say----someone here was to make a limited batch of handmade amps that were very easy on the pocketbook----I have a few questions---
1----what options would you want---power wise and such
2----what size would be the best
3----what class would you want
4---and finally would you buy from someone here building amps?
just wondering :D
Dave if your making them, I would buy from you for sure, this is what your getting at right?
1- crossvers and RCA passthrough, strappable
2- nothing too big but no need to go crazy small either
3- solid A/B and or T class
4- maybe
i have the same answers as denim, including for sure buying one from you, if funds are ok at the time.
now, get to building..lol!
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
sweet!
so...
are u building yet? :stfu:
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
1. Sub amp with regulated PS ( 1000W area) or like acidburn said a 200W component amp
2. I would want something that is decient. Nothing super big.
3. A/B and T woulc be cool too
4. Depends how it peforms/looks
I know its peformance over looks but most people dont want ugly amps.
i like ugly amps like Elias amp he tried to paint.
i would buy one. 400x2 at 4 ohm would be better....
It looks way better in black so SHUT IT
400x2 is to much power.
lol. powercoat it!.
i like headroom thats good power right there. :slayer:
1. 200x2@4ohms, 100x4@4ohm, 1000x1@1-4ohms. I also like all the wiring/controls in the front of the amp as opposed to the sides.
2. thin, longer amps instead of thick, wide amps.
3. a/b
4. I would buy from someone here if I had any money lol.
I got dibs on dealer rights, hehe j/k
anyway my question dave (since I dont know off hand)
which class amps are more durable and less expensive to make?
A, B, A/B, D, T, H ????
and would you be able to build a sub amp that is versitle, like the new the PG's and JBL's where it produces similar power @ 4,2, and 1 ohm loads,
I think your market would be making limited edition, super HQ, amps that are pretty efficent
maybe Zapco C2K level but not C2K price? (crosses fingers)
Class D by far is the cheapest to build----Class AB for durability and overall power to sound.
I have never tried a common ohm power amp---I'm sure that I can find out about them though.
I am checking into semi-switching PS----IE---runs Class AB until current is needed and switches then to a Class D----kind of like a hybrid amp.
I have desided to make only about 3 or 4 amps----keeping the Beta version for myself of course-----NOW---I am going to be doing this in my spare time and if anyone here knows me knows I don't have much---but I will try.
If someone made a pair of single-ended solid-state amps, I would be all over that :D
120VAC.
Class A single-ended, one output device per channel.
Monoblocks, maybe 10-15wpc.
The least amount of negative feedback as possible.
Basically, a cheaper version of Nelson Pass' Zen monoblocks.
http://www.passdiy.com
Spoogerific.
dave, if you are going to only make a few amps, I would say go for an all out SQ loves front stage amplifer, but then again with making so few won't that keep the costs high?
I would like a class A/B high SQ amp or monoblock; right now, I need a 2 channel that does between 75-150 @4 ohms and double that @ 2 ohms. A 4 channel would work as well. Are you planning to have a high slope crossover built in or none?
If I were making three amps for a discerning crowd:
1) 1500.1 sub amp
2) 200x2 Front stage amp
3) A take off on the component amp idea, but in 4 chn.
150x2 for mid
50x2 for tweet or alternatively wire to 300x1 & 50x2 for lower cost systems
Maybe item 3 is for too much a niche market, but man would that make life simple, ESPECIALLY if you added crossovers (one post late here).
Pure gain blocks. No internal crossover/boost/etc. (a la Linear Power, Coustic DR, etc)
Accept balanced inputs; either via dual RCA's or mini-Din connections.
Independent gain controls for each channel.
Unregulated PS.
200-400w x 2 @ 4ohm
200w x 4 @ 4ohm
And a solid subwoofer amp.....whatever size doesn't matter. I'm not a bass head anymore :P
Then a 25w x 2 @ 4ohm amp for those high efficiency users (horns, ribbons, etc).
Maybe a nice 3-channel for comps and a sub.....200w x 2 @ 4ohm of A/B power, then 1000w x 1 @ 1ohm of class D power all in one chassis with separate inputs for the front and sub channels.
Physical size? Something on the order of the Helix amps would be cool. Thin. Smaller sized. Able to put anywhere.
Class A/B for comps, Class D for sub.....then make that baby amp a pure class A :rockwoot: Who needs efficiency anyways?!?
I'll try anything once ;)
Well, not anything....but you get the idea.
And I want to see some "old school" cheater amps again.
Something like the Orion 2100 HCCA:
100W X2 @ 4 OHM
200W X 2 @ 2 OHM
400W X 2 @ 1 OHM
800W x 2 @ 0.5 OHM
400W X 1 @ 4 OHM
800W X 1 @ 2 OHM
1600W X 1 @ 1 OHM
.5ohm/channel stable....YUMMY!!
Oh, that's one thing I forgot to mention. Make the 2 and 4 channel amps 1ohm/channel, 2ohm/bridged stable!!!
