hello i have two JBL GT4-12 sub woofers which mono amp would be best to power them up.
Subwoofer Specifications
Subwoofer Size 12"
Voice Coil(s) Single
Impedance (per voice coil) 4 ohms
Peak Power Handling 1000 watts
RMS Power Handling 250 watts
Woofer Composition Polypropylene
Woofer Surround Rubber
Sensitivity 93 dB
Frequency Response 23 - 450 Hz
Xmax (millimeters) N/A
Top Mount Depth 6.25"
Cutout Diameter 11.14"
my budget is 300$ :blush:
please kindly reply
regards
simmer
Are you looking to run the woofers in parallel to a 2 ohm load?
Looking for a monoblock or 2 channel?
Yeah, I think wiring the woofers to 2 ohms would be the best option for you. Then finding an amp based on that would be much easier.
  • Admin
That Sundown is a great option. We hope to have the Stetsom Venom line up on the SSA Store soon as there is a 500watt model that would also be great for this application.
I was looking for that line to see what was available for the OP as well!
Sundown Audio SAX-1200D hmm... exactly 300$ wow i'll purchase it asap after talking it abt my friends :)
cheers :popcorn: :popcorn: :popcorn:
alpine mrp500 500 watts @ 2 ohms
thanx for replying very nice amp
btw i have a question for u
my subs are rated for 250W/4 ohms each...in parallel that's 2 ohms & total power of 500W.i'm i right ?
and what do u think about this amp it's also a D class amp
http://www.sony.co.in/product/xm-gtr3301d
btw SAX-1200D is RMS power 2 ohm mono 720W x 1CH
720W and i need 500W ,600W would be ok.don't u think 720 will blow up the subs ?
I'd stay away from any sony product.
If you set the gain correctly it wont hurt a bit having an amp that can put more power down than the sub can handle, its actually a good thing (search for "headroom").
and x3 for sundown!
sir i can't purchase the SSA :'( online.
only few good companies are avail in my country
pioneer kenwoord xplod jbl and kicker
could u please check this amp this is cheap and better than the xpload one.
GM-D8500 M Class-D Mono Amplifier
http://www.pioneer-india.in/Product.aspx?id=63
