Posted September 25, 201015 yr Right now I'm building a new box for one 8" sundown Sa-8 that I'll be using until I get another 1 or 2. My current box is tuned too high for my liking.How much square port area is recommended for these subs?What is the lowest you would recommend I tune the box to?Right now I'm tuned to 34 hz, between .75 and .85 cubes after displacement by messing with some dimensions, with 13 inches of square port area. Is this enough for one Sa-8? I don't want to make too big of a box for it per Jacob's recommendations.Thanks.
September 25, 201015 yr Author you should be good where your at. how much power are you using?Thanks for reply - about 500 @ 2 ohms.
September 30, 201015 yr Author So - I thought I'd come back after building the box and let you guys know how it worked out.IT !@#$ING SLAMSI ended up netting .75 cubes @ 36 hz and I love it. Now I want more of these.
October 1, 201015 yr what is the displacement factor for the sa-8? I have a gross box size of 1.10 cuft
October 1, 201015 yr So - I thought I'd come back after building the box and let you guys know how it worked out.IT !@#$ING SLAMSI ended up netting .75 cubes @ 36 hz and I love it. Now I want more of these.What happened to not liking the high tuning? You said you didn't like 34hz then went with 36hz. What made you change your mind? And where is a video!
October 1, 201015 yr what is the displacement factor for the sa-8? I have a gross box size of 1.10 cuft.10
