September 28, 201014 yr If you do a wall i would run a min of 10k, when putting that much work into walling off your ride and only running small power is a waste of time IMHO.I'm running about 8k in a S-15 ext cab....So if you wall it get that shit moving with 15k!!!! Note: i forgot what subs your running lolNightshade V.2's can take a decent amount of power butt idk about that much lol. I would run a SAZ-4500d or equivalent power to each sub If I end up going all out which it a MAJOR possibility.Is there a possibility of changing subs?Yes, I could change subs but I live like 10 mins from sundown so it is very convenient for me to pick up my subs + I already have 1 18. I could do 3 18's but my port would have to be over the subs all the way across which seems a bit unorthodox to me. I could also do 4 15's.... Then it just comes down to the cost of things lol.(2) 21" drivers would be amazing
September 28, 201014 yr Author you could always get your shades upgrades, are they v.1 or v.2's?I have a V.2 right now in my car (Great subs BTW). I have 600$ in hand to drop on another sub..... and I actually debated on whether or not to get some 21's but decided against it because the most cost effective thing would to just get another NS V.2 or a third haha.
September 28, 201014 yr The v.2's take hell of a lot of power to be honest, if you have enough space, i'd do 4-15's recone the 18's to 15's then wall that shit!
September 28, 201014 yr I would say 30hz would be plenty low. There is not much music that plays below that and you box is not going to stop at 30 it would play a little below that.Honestly, I was thinking of stuff from like the 25-26 hz range.... Right now my box is tuned to about 29 hz with one NS. V.2 18 and I still desire a lil more low end output...I love Ed Hicks setup peaks at 155.2 db at 25hz with only 9k watts If I could do a 150 at 25hz I would be sooo fuckin happy. 4th order time?Umm, you are already running a 4th order.Hey thanks guys I guess I have come to the conclusion that I should just keep tuning the same and just double cone area and power and after that think about lowering tuning... Sound about right?I'd try a Bandpass personally if I was going to get low again. Terrible idea. Tuning really low and bandpass won't exactly let you play music. By default they are going to pass a small band.And yes, doubling your cone area and power is a much better idea than lowering your tuning. Assuming of course you have enough space.
September 28, 201014 yr After What I seen / heard this weekend, 16 10s (tuned / sealed) was wild playing way low notes and loud / clear music and still around 150db+ on the meter !!! Awesome work TJ Lacharite (not to mention this is a SQ vehicle) ...
September 28, 201014 yr You have the money, you live near Sundown : just get a second nighthshade. build a strong box and play with power !!!The wall looks cool, but I would not want one in my car!!
September 28, 201014 yr Author I would say 30hz would be plenty low. There is not much music that plays below that and you box is not going to stop at 30 it would play a little below that.Honestly, I was thinking of stuff from like the 25-26 hz range.... Right now my box is tuned to about 29 hz with one NS. V.2 18 and I still desire a lil more low end output...I love Ed Hicks setup peaks at 155.2 db at 25hz with only 9k watts If I could do a 150 at 25hz I would be sooo fuckin happy. 4th order time?Umm, you are already running a 4th order.Hey thanks guys I guess I have come to the conclusion that I should just keep tuning the same and just double cone area and power and after that think about lowering tuning... Sound about right?I'd try a Bandpass personally if I was going to get low again. Terrible idea. Tuning really low and bandpass won't exactly let you play music. By default they are going to pass a small band.And yes, doubling your cone area and power is a much better idea than lowering your tuning. Assuming of course you have enough space.Haha my bad I was saying 4th order as in a 4th order bandpass and forgot that all ported enclosures are also 4th order enclosures... and I guess that is not a very good idea then...
September 28, 201014 yr you could always get your shades upgrades, are they v.1 or v.2's?He has v.2's
