August 14, 201115 yr Author Boy bro, you got a lot of work ahead of you. If there's anything I might be able to do to help from all the way down here, just let me know! :drink40:thanks bro!
August 14, 201115 yr Author As far as the foam on the paint, I would try to buff it out with a light cutting compound. You may need to re apply some clear coat then buff again.Based on your tastes a big 8"-12" midbass driver in each door along with a couple fullrange drivers (no dedicated tweeters) in the dash corners or a-pillars should make you happy right on, i will tackle the paint once the build is complete...few other attributes i want to address all at the same time with the finish,i am thinking about using the 100.4 for the four midbass and the 100.2 for the midrange.....skipping the tweeter sounds like a good approach, easy to add later if i feel lost without it.good advice bro!
August 14, 201115 yr Author It hurt to let those batts go but I know they'll be put to good use ........and the fact that they go to my lil brotha is what puts a smile on my face thanks brother!they will fit the bill ever so nicely!
August 14, 201115 yr As far as the foam on the paint, I would try to buff it out with a light cutting compound. You may need to re apply some clear coat then buff again.Based on your tastes a big 8"-12" midbass driver in each door along with a couple fullrange drivers (no dedicated tweeters) in the dash corners or a-pillars should make you happy right on, i will tackle the paint once the build is complete...few other attributes i want to address all at the same time with the finish,i am thinking about using the 100.4 for the four midbass and the 100.2 for the midrange.....skipping the tweeter sounds like a good approach, easy to add later if i feel lost without it.good advice bro!I have been dreaming of a front stage setup that consists of one of these Selenium 12MB3P 12" mounted in each door for midbass. And one of these Audience A3 3" Full Range Driver mounted in the dash corners. I am sure it would sound amazing and get ridiculously loud The Selenium's are more efficient than the Audience's but if crossed over correctly that could be beneficially for some added midbass bump.I am anxious to see what route you choose. I am definitely doing a two way setup in a future build, hopefully with he drivers listed above.
August 14, 201115 yr Author subwoofers 2 18" SSA Xcons beefy surrounds!18" Thorson cresent wrench putting things in perspective!
August 14, 201115 yr Whoawhoawhoanow you messing up!!! Sundown fronts & different for bass? Wth are you thinking??Lmao j/k
August 14, 201115 yr Author Whoawhoawhoanow you messing up!!! Sundown fronts & different for bass? Wth are you thinking??Lmao j/khell, i thought i was doing good having two of the same brand subs in one enclosure, and they are even the same diameter!
August 18, 201115 yr Author Damn Chop, the only pic I got of the Car at Slam!i guess i am not sure who's screen name this is, but it is a dam nice pic, imho! progress is creeping forward a bit now!
August 18, 201115 yr Author Right on! i was trying to think of all my sd buddies, lolgood to see you on here!hope all is well, have not gotten to chill at tru near enough lately!
August 19, 201115 yr Yeah well we should be there Tomorrow night. Gonna have a few more people there that aren't normals. Gonna be a good time as usual !
