Posted September 29, 201016 yr this might be a dumb question, but can u wire dual 1.4 ohm speakers to 1ohm or do you just have to wire to .7- if you have to wire to .7 can you explain how to do that please?
September 29, 201016 yr Author only .7.....Wire in parallel +to+ -To-so wire the positive on one side to the positive on the other, then the same with the negatives and then run a wire from the positve and one from the negative that goes out. is that correct?
September 30, 201016 yr You are reading the DCR of the coils, they are D1 speakers.If it's 1.4ohm/coil, that would be a D2.
September 30, 201016 yr You are reading the DCR of the coils, they are D1 speakers.If it's 1.4ohm/coil, that would be a D2.He said each coil was .7
October 1, 201016 yr You are reading the DCR of the coils, they are D1 speakers.If it's 1.4ohm/coil, that would be a D2.He said each coil was .7 No, he asked if you could wire to 1ohm or if the only option was to wire to .7, which for a single sub would mean each coil is 1.4Learn to read n00b
October 2, 201016 yr You are reading the DCR of the coils, they are D1 speakers.If it's 1.4ohm/coil, that would be a D2.He said each coil was .7 No, he asked if you could wire to 1ohm or if the only option was to wire to .7, which for a single sub would mean each coil is 1.4Learn to read n00b Aww poo. You right Brad
