Posted October 17, 201014 yr I've decided to build a box for my 15" SSD that will fit in my trunk. I was wondering if these numbers sound right or what it really should be. LolBox will be 28" wide, 17" tall, and 22" deep. Port is 3.5" wide and 21 inches long. Looking to be around 4cuft tuned around 31- 33hzDoes this sound right?? If not help is very appreciated! Edited October 17, 201014 yr by xAndrewx
October 17, 201014 yr I got 3.52 @ 39hz with those measurements after sub displacment and double baffleWith the port 3in wide and 26in long it comes to 3.75 @ 32.5, thats at 12.4cu port arealmk if that was any help to you Edited October 17, 201014 yr by hardrock2401
October 17, 201014 yr I got 3.52 @ 39hz with those measurements after sub displacment and double baffleme too,
October 17, 201014 yr Author I got 3.52 @ 39hz with those measurements after sub displacment and double baffleWith the port 3in wide and 26in long it comes to 3.75 @ 32.5, thats at 12.4cu port arealmk if that was any help to youdamn i'm having issues. i had to play with some measurements back and forth a few times. i'm thinking it's supposed to be as you said, '3in wide and 26in long it comes to 3.75 @ 32.5, thats at 12.4cu port area'does that sound better?
October 17, 201014 yr Author here's what it should look like at 28" wide, 17" tall, 22" deep, 3" port 26" long
October 18, 201014 yr Author whats the car?99 corolla. loltrunk is pretty smallJust out of curiousity what amp are you using man?audioque 1200dworks beautifully
October 18, 201014 yr k, if firing back, make the box as wide as possible and as short as possible, put a nice big round on the top edge of the box, remove the spare tire cover and all the spare tire stuff (as the box will be on it anyways cant get to it, plus it gains half db ) make the box so it is 6-8 inches from the trunk lid. thats all i got really for this, if you want lows, tune to 32-34 hz with a kerf.
October 18, 201014 yr Author k, if firing back, make the box as wide as possible and as short as possible, put a nice big round on the top edge of the box, remove the spare tire cover and all the spare tire stuff (as the box will be on it anyways cant get to it, plus it gains half db ) make the box so it is 6-8 inches from the trunk lid. thats all i got really for this, if you want lows, tune to 32-34 hz with a kerf.thanks for the advice!the sub will be firing back. i'll probably put some short legs on the front of the box to keep it close to the lid, but unable to slide into it.
October 19, 201014 yr looks good to mesweet, thanks mananytime man, just lmk if you need anything else
