Posted October 18, 201015 yr So i talked to Kyle and he said I would be plenty satisfied with a 250amp alt for my jeep. Im putting in 2 18s NS v2 and a single 4500. And eventually upgrading doors speakers. My question is will i just replace my oem alt with this one or will i need a dual bracket?
October 18, 201015 yr Well the easiest way is to replace your stock alt with the dc alt, but you could possibly get a dual alt bracket made and run your stock alt for stock electrical and run the dc alt for your stereo.If you did the later approach, you would have more amperage to keep up with your current draw from your amps, and you could run a higher voltage which would be beneficial for an amp such as a saz4500 I guess the only issue is, do you have space under the hood for a second alt? Some people remove their A/C to make up the space, I know if it was me I'd never do that... I'm not sure off the top of my head how much current draw the 4500d has at full tilt, I'm assuming your wiring it down to 1ohm? Depending on the current draw and battery bank you have, it may or may not be worth it to do a dual alt setup.Hope that helps, even the slightest bit!
October 18, 201015 yr Author im not sure if i would have space under my hood for that. clueless on that. and yea ill wire it to 1ohm.
October 18, 201015 yr Are you planning on running extra batteries? If so, any idea on which models and how many?
October 18, 201015 yr Author Are you planning on running extra batteries? If so, any idea on which models and how many?yea im planning on xtra batts. probably at least 2(IDK if i need more) and no idea on which models.. thats one reason why im here on this wonderful forum , maybe someone can help me out with everything I need
October 18, 201015 yr I'd go with xs power batteries, there powerful and bombproof But they do cost a bit compared to other batteries such as kinetik.After you get your alt in, get a couple batteries and check your voltage at full tilt, if it's dropping into the 12.5v range consistently then I'd get a couple more batteries and check again.You don't want to be discharging your batteries the whole time your playing at full tilt, but they can pick up the slack that the alt can't manage.This amplifier can draw HUGE amounts of current - in excess of 500 amps - you MUST have a very large high output alternator (250-300 or more amps) AND 3-4 Group-31 batteries to power this amplifier (we suggest XS Power D3100s or Stinger SP2150s). -Sundown AudioPerhaps running your stock alt and dc alt would be a good idea...
October 18, 201015 yr Honestly, a single 250XP and a couple batteries will be fine.. I would run our PCM bypass and internally regulate the alternator just because it will run stronger on your vehicle which runs an extra $80, but it's well worth it on vehicles like yours.. From our experience with the amp your running though, 250 should be plenty.. Rob
October 19, 201015 yr Author Honestly, a single 250XP and a couple batteries will be fine.. I would run our PCM bypass and internally regulate the alternator just because it will run stronger on your vehicle which runs an extra $80, but it's well worth it on vehicles like yours.. From our experience with the amp your running though, 250 should be plenty.. Robso no dual bracket will be required.. just replace my oem alt? thanks for all the help guys.. much appreciated
October 19, 201015 yr Honestly, a single 250XP and a couple batteries will be fine.. I would run our PCM bypass and internally regulate the alternator just because it will run stronger on your vehicle which runs an extra $80, but it's well worth it on vehicles like yours.. From our experience with the amp your running though, 250 should be plenty.. Robso no dual bracket will be required.. just replace my oem alt? thanks for all the help guys.. much appreciatedreplace stock with DC and your a happy camper...
October 19, 201015 yr Author Honestly, a single 250XP and a couple batteries will be fine.. I would run our PCM bypass and internally regulate the alternator just because it will run stronger on your vehicle which runs an extra $80, but it's well worth it on vehicles like yours.. From our experience with the amp your running though, 250 should be plenty.. Robso no dual bracket will be required.. just replace my oem alt? thanks for all the help guys.. much appreciatedreplace stock with DC and your a happy camper... thanks guys!!
